Page 1 of 6 123456 LastLast
Results 1 to 10 of 60
Thread: *** New Product *** MJS Gadgets USB-IO-1
    MySQL Error
    Oct 2004
    I got a new Product, available in days, from right here at mp3Car.com
    (Why announce here, cause I designed it for primarily Ride Runner, and I love you guys )
    its a USB I/O interface
    Its not meant to compete with any existing one out there, just be simpler
    Its in the same size ENCLOSURE as my UAS4 (USB Audio Selector)
    (so approx 3" x 2" x 1")
    the Key is the Ride Runner Plugin i did, hopefully i thought of everything
    (which of course i didn't, but it can expand it as requested)
    the manual is attached
    Features:
    • USB Powered and Controlled.
    • USB HID Device – No drivers needed.
    • 4 – Relays (1 amp) selectable Normally-Open or Normally-Closed
    • 4 – Digital Inputs (5 – 30 volt opto-coupled).
    • Plug-able Terminal Blocks, (Phoenix style).
    • Road Runner plug-in available.
    • Centrafuse plug-in available.
    • Developer .DLL available. (.NET Based)
    • Includes 6’ USB A to Mini-B Cable.
    Some things you can do with it:
    • Control Power Antenna
    • Control Audio Amplifiers
    • Control Power Window Module
    • Control Accessories
    • Control Incoming Phone Call Notifier (Led in cluster)
    • Detect Parking lights on
    • Detect Parking Break (to allow video)
    • Detect Car in Park (to allow video)
    Almost unlimitied ideas...
    (yes you can use more than 1)
    Suggested Retail $55
    Some Pictures:
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    Ride Runner - Plug-in Documentation
    (yuck #code formatting, looks bad, readme.txt is attached)
    Code:
    RideRunner Extension Plugin for MJS Gadgets USB-IO-1
    !REQUIRES .net 2.0 sp2 framework
    u = Unit number 1 - n
    r = Relay number 1 - 4
    s = State 1, true, 0, or false
    is = Input State "ON" or "OFF"
    serial = MJS Gadgets USB-I/O-1 Serial Number String
    var	= RideRunner user variable
    ** SKIN COMMANDS
    "MJSGIO_ALLOFF;u"								- all relays off.
    	ex. MJSGIO_ALLOFF;1						- turn unit #1's relays off.
    "MJSGIO_SETRELAY;u;r;s"					- Set a relay on or off.
    	ex. MJSGIO_SETRELAY;1;2;1			- sets unit #1's relay #2 on.
    	    MJSGIO_SETRELAY;1;1;0			- sets unit #1's relay #1 off.
    	    MJSGIO_SETRELAY;1;3;true	- sets unit #1's relay #3 on.
    "MJSGIO_EVENTS;u;s"							- Enable/Disable events for unit.
    	ex. MJSGIO_EVENTS;1;true			- Enables unit #1's events.
    	    MJSGIO_EVENTS;1;1					- Enables unit #1's events.
    	    MJSGIO_EVENTS;1;0					- Disables unit #1,s events.
    "MJSGIO_GETUNITID;serial;var"								- Searches system for device with serial number
    																							and assigns user variable with unit number.
    	ex. MJSGIO_GETUNITID;21436587-1450-011F080C7-02AF8598B518;iodevice
    																						- will set iodevice with unit number if found
    																						- Events, "ONMJSGIO_GETUNITID.SUCCESS" &
    																							"ONMJSGIO_GETUNITID.NOTFOUND"
    ** EVENTS
    "ONMJSGIO_START"														- Fired when Plugin is running, after ONSKINSTART
    "ONMJSGIO_GETUNITID.SUCCESS"								- Fired if "MJSGIO_GETUNITID" is successfull.
    "ONMJSGIO_GETUNITID.NOTFOUND"								- Fired if "MJSGIO_GETUNITID" is unsuccessfull.
    "ONMJSGIO_INPUT.u.i.is"											- Fired when MJSGIO_EVENTS are enabled for this unit (u)
    																						- i = Input number 1-4
    																						- is = Input state "ON" or "OFF"
    	ex. ONMJSGIO_INPUT.1.1.ON									- Unit #1's Input #1 is ON
    	ExecTBL.ini ex.
    		"ONMJSGIO_INPUT.1.1.ON","PlaySound;$RRPATH$Plugins\RRMJSGUSBIO\Example\boing_x.wav"
    ** SKIN LABELS
    ** SKIN INDICATORS
    "MJSGIO_RELAY;u;r"													- Indicates current state of relay (true = on, false = off)
    	ex. MJSGIO_RELAY;1;1											- Indicates current state of unit #1's relay #1.
    "MJSGIO_INPUT;u;i"													- Indicates current state of input (true = on, false = off)
    	ex. MJSGIO_INPUT;1;1											- Indicates current state of unit #1's input #1.
    ** USAGE NOTES
    ** THANKS
    ** HISTORY
    v1.0.0 Initial Release
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I think one key thing to add to your list, is the ability to use it to control voice recognition. You could hook a momentary switch to it, and have it trigger RR to listen for commands when using the voice recognition plugin by jebus.
    My Fiero Build Thread
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Thanks, that's very cool. The voice control thing is a good idea, although I personally have it solved already.
    Could it be used to control like RGB leds, like blue for speed trap, red for incoming calls, green for incoming phone calls, bright white when doors open, etc.? (say you have a led strip in your instrument cluster, wherever - but which can change colors according to I don't know what controls those rgb things, resistance, pulses?).
    On second thought, I think the above would work best if it could work w/o the computer being on though...
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    As it is right now, you could hook a couple of different color LED strips to different relays. Turn on the one you want for the color you want ect. Talking to Mitch, me mentioned you could also have say a red and a blue hooked to different relays, and turning on both would give off purple light.
    Of course that is just a temporary solution.... Until.... say..... ummmm.... another "Gadget" comes along?
    I'm just saying.....
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Cool interface !
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by JohnWPB View Post
    oh you know too huh lol cant wait!
    Live mp3Car Facebook Chat
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Awesome gadget! Ill be purchasing one. I have been waiting for a simple USB controlled relay bank for some time now. The real purpose is to control external circuits from touchscreen buttons. (Example, ground trigger your headlight switch from RR, or positive trigger your amplifier from RR, or lock unlock your doors from RR)
    It can be used to control even higher draw circuits if external relays are added.
    I suppose you could use it to light up some LED's or integrate it into voice control contraption, but IMO these ideas are really missing the point of the device. This is my opinion though and everyone will have a different use.
    Jul 2005
    Motorcity
    Blog Entries
    1
    For S & G's I may have to add a "start / stop" button to RR to fire up and shut down my engine
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Got to find a way to use it in my up coming Sienna.
    Too many good stuffs, no time to play with.
    Still have the HD radio cable in the package unopen from 2-3 years ago.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. MJS Gadgets UAS - comming soon to carpc near you
    By mitchjs in forum Road Runner
    Last Post: 08-14-2012, 05:24 PM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  3. Lillput USB problems
    By the_big_1 in forum LCD/Display
    Last Post: 11-22-2008, 12:00 PM
  4. *NEW* USB 16 Isolated High Current Digital Outputs, IOPoint-USB
    By bibaja_llc in forum Hardware Development
    Last Post: 07-04-2007, 10:47 PM
  5. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
