Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: RR 02-01-2011 Release
    MySQL Error
    Oct 2004
    Holly CR/\P its February already!!
    Download HERE
    Not much here, a tweak or two...
    Some Highlights:
    • NetRadioArt
    • Skincommand; "RESTORE" restores RR window (from minimized)
    • Winamp Player Play list file name option; "*.extinfo.m3u" or "*.extinfo.m3u8"
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    1/29/2011
    + Winamp Player Play list file name option; "*.extinfo.m3u" or "*.extinfo.m3u8"
      If the file name of the play list loaded into RR ends like above, its
      passed directly to winamp, vs RRs existing method. Therefore all paths
      to audio files must be correct or they will not play. Best used for URL type
      play lists.
    1/21/2011
    + When playing a URL (Net Radio), Albumart will attempt to use:
    	"NetRadio_xxx.xxx.xxx.xxx" where xxx.xxx.xxx.xxx is the IP/URL.
    	Using .png or .jpg or .gif as extension.
    	NOTE: : and / are translated to .
    	examples: http://82.201.100.23/Radio538 becomes "NetRadio_82.201.100.23.Radio538"
    					 	http://216.155.137.150:8000 becomes "NetRadio_216.155.137.150.8000"
    	when a URL image file is not found, the albumart will default to:
    	"NetRadio.png" (remember, .jpg allowed too).
    	These images are stored in the folder: "NetRadioArt" (from RR ROOT)
    1/19/2011
    * Minor tweak to Silabs radio, TA signal must be valid for 1 second before ONRDSTASTART is fired.
    * Minor tweak to HD Radio, since no stereo indicator is provided by tuner, its faked if Signal Level > 50%.
    01/11/2011
    * Desktop Composition is disabled by default on Windows 7, setting, if existing install
      you might want to consider setting it to false in rr.ini (DisableDC=false)
    # Added proper Activation focus back to skin when dimmer is activated
    + "MediaCarExecTBL.ini" this file is read in with global Exectbl.ini to add
      some commands that the OLD mediacar front end supported, and are obsolete in RR, while
      these commands could have been added to existing ExecTBL.ini at anytime by anyone
      they are all now in this file.
    01/04/2011
    + Skincommand; "RESTORE" restores RR window (from minimized)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Cool
    Constant Bitrate mstaedt's Avatar
    Dec 2007
    Just curious, how does one invoke the "RESTORE" command if RR is minimized?
    Project completed! (almost)
    My Truck as featured in Custom Classic Trucks magazine.
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    I use this in RRVoice. Put this in the menu.ini file-------> Restore=Restore or Maximize=Restore. Works great! Thanks mitch.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by RAWPWR View Post
    Just for anyone wanting to copy and paste, they need to be on different lines, but you can have both:
    Restore=Restore
    Maximize=Restore
    My Fiero Build Thread
    May 2008
    Bordeaux, France
    Clsetimg
    I should like to know how to use the CLSETIMG option into a custom list.
    I wanted post this question into the RoadRunner thread but it is dead into this new forum version
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Custom Icon
    Quote Originally Posted by pierrotm777 View Post
    Here is the line from my skin. I have a CL in my menu.skin
    The custom icon is called select.png which should be in your skin folder. You can name it what you want, just change the line to your needs, then it will show that file in your CL.
    Apr 2006
    Sydney, Australia
    Thanks for that Mitch
    New Car PC Build list in progress
    May 2008
    Bordeaux, France
    Quote Originally Posted by MGD View Post
    I know that,but thanks.
    I should want to have a different icon by line.
    I know this possiblity:
    0
    LSTLine1||This is line 1
    LSTLine2||This is line 2
    Does exist another method ?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    The only methode for different images in Custom Lists is this command.
    "CLSETIMG;1;$SKINPATH$ListIcon1.BMP"
    "CLSETIMG;2;$SKINPATH$ListIcon2.BMP"
    "CLSETIMG;3;$SKINPATH$ListIcon3.BMP"
    "CLSETIMG;4;$SKINPATH$ListIcon4.BMP"
    "CLSETIMG;5;$SKINPATH$ListIcon5.BMP"
    Now you can have 5 differnt icons in the list.
  1. Alpine AINet CRC solved
    By viper_1 in forum Car Audio
    Last Post: 09-17-2015, 04:15 PM
  2. RR 10-04-2010 Release
    By mitchjs in forum Road Runner
    Last Post: 10-31-2010, 12:23 PM
  3. RR 12/01/09 Release
    By guino in forum Road Runner
    Last Post: 01-06-2010, 09:51 AM
  4. RR 05-28-05.. Early Release..
    Last Post: 06-04-2005, 09:36 PM
  5. RR 2-27-05... LATE Release (Fixes)..
    Last Post: 03-02-2005, 01:27 PM
