Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: problem with "WRITETOFILE"
    Low Bitrate topjohn's Avatar
    Oct 2009
    France /Wissous
    Hello,
    I have a problem with the "WriteToFile"
    When I write this:
    WriteToFile; $SKINPATH$ toto.txt; = "toto, toto, toto"
    and when I open the file toto.txt, there to write it:
    "tot
    In fact I think we can not write a comma in quotes because when I put the same function without any point he writes well in the txt file.
    example:
    WriteToFile; $SKINPATH$ toto.txt; = "totototototo"
    here is what he has to file toto.txt:
    "totototototo"
    It's good that the problem is the comma, is there a solution to this problem?
    Greetings.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    put in skin.ini
    com=,
    then in your "toto$com$toto$com$"
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Oct 2009
    France /Wissous
    YESSSS
    thank you very much, I tried it in a variable, but it did not work.
    in skin.ini is ok.
    MySQL Error
    Oct 2004
    NO PROBLEM here,...
    this works fine
    WRITETOFILE;E:\TEST.INI;="BLA,BLA"
    in my file is:
    "BLA,BLA"
    since you provide no information, i can only suggest use the newest riderunner
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Now, why on earth would you need "BLA,BLA" in a skin file?
    Oct 2009
    France /Wissous
    I do not want to write to a file. INI, I want to write in a txt file and confirm that if we do not place the comma in the ini file, it does not work
    MySQL Error
    Oct 2004
    sure it does!
    WRITETOFILE;E:\TEST.txt;="BLA,BLA"
    will write, to a file named "test.txt" on root folder of drive E, with the contents:
    "BLA,BLA"
    (including the qoutes, which must be there if you want , inside)
    and again, since you provide no infomation, i will suggest you use the latest riderunner
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The issue here is the use of comma WITH quotes in the manner you're using. Generally you should have no issue but if you do, you can use this trick:
    "SETVAR;COMMA;,||ADDTOFILE;C:\Test.txt;="boo$comma $boo"" however these versions should work directly without needing anything:
    "ADDTOFILE;C:\Test.txt;='boo,boo'"
    "ADDTOFILE;C:\Test.txt;="boo","boo""
    If you execute the command from a plugin/script (i.e. skintool) it should work in the original format. It is just hard to think of all the possible uses for the command when we make it.
    Ride Runner RR's Myspace
    Oct 2009
    France /Wissous
    Thank you Guino
    I have another problem, I just installed on my PC windows7 home, but when I run RR, there must be problems right director, because I normally IBUSRR which launches at startup with the "RUNQ "in Exectbl.
    But it does not start, so I tried to boot RR as an administrator, but it does not start.
    By cons with Skintool run as administrator, it works, it nevertheless starts IBUSRR.
    No problem in XP
    MySQL Error
    Oct 2004
    rr when started will automatically ask for elevation... its built into the manafest... if you set it .exe to run as admin, you wont get nagged
    but that has nothing to do with IBUSSRR... which is 3rd party
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Replies: 0
    Last Post: 09-13-2007, 02:28 PM
  2. "writetofile" "addtofile"
    By Chuck in forum Road Runner
    Last Post: 10-10-2006, 07:48 PM
  3. Replies: 5
    Last Post: 06-20-2006, 01:20 PM
  4. Replies: 2
    Last Post: 08-09-2004, 03:49 PM
