Results 1 to 6 of 6
Thread: Visualisation won't embed
    Apr 2007
    I've upgraded to one of the latest versions of RR (will check version tonight), as I was having trouble with album art being displayed. This is now fixed however I have now noticed that the visualization will no longer embed. Confirmed it's not working with both Carwings and the Crystalblue skin I am using. Using winamp AVS. Was embedding fine before the upgrade - in crystalblue the albumart areas is the same as the viusu area.
    Any ideas where to start?
    MySQL Error
    Oct 2004
    in carwings, visu is set as a transparency type... (AVS set as visual in winamp v5.6 classic)
    in Carwings_Dynamic_Lite folder, in skin.ini:
    visuname=!Winamp Gen!AVS
    transparentvisu=true
    opacityvisu=40
    these will override any rr.ini settings for this skin...
    and as you can see.. works great!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Apr 2007
    Cheers, will give it a try
    MySQL Error
    Oct 2004
    its not really try, cause what i was saying, this is how carwings is set up, all you have to do is set winamp to use AVS
    might need winamp in classic mode, i dont know, but it should just work
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Apr 2007
    hmm, still having no luck. using RR version with last history.txt entry of 12/18/2010/
    using winamp v2.95
    MySQL Error
    Oct 2004
    thats older, oh and the images i dont see... forum issue i guess...
    winamp 2.95 could be your problem, thats like 10 years old
    maybe AVS window name is different on it, i suggest the newest winamp
    install in classic mode
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Visualisation for foobar
    By anuchit in forum RR Plugins
    Last Post: 06-09-2011, 12:40 AM
  2. Winamp Visualisation
    By nashakontora in forum Road Runner
    Last Post: 11-23-2007, 05:39 PM
  3. embedding visualisation
    By holistic in forum Road Runner
    Last Post: 02-17-2005, 02:20 PM
  4. For the visualisation problems into the V1.9
    By coyote in forum MediaCar
    Last Post: 03-04-2004, 05:05 PM
  5. Mediacar and visualisation
    By jim22 in forum MediaCar
    Last Post: 03-01-2004, 06:14 AM
