Results 11 to 20 of 27
Thread: Menu popups with transparancy and you
  1. #11
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    hi mitch,
    i work with this new function...and it works very well.....but....the notes for it inside the skin commands.txt are not well.
    the notes inside telling me that POSx and POSy are relative to the values inside the general.ini.
    thats only the half truth. its when you fix the value -0- (PosX=0) your object would be place in the center of your screen.
    if your object has the same width as your screen, its no problem...but, the Y position is also in the center.
    if its your willing to place the object in the center...its ok, but please give a note inside skincommands.txt file.
    a second question about it,
    my skin is 800x600 pixel, the object i popuped is 800x450 pixel. if i poped it, no other label, button, slider aso. i canŽt change.
    so i must wait that the fixed timer is ended, or go my way and put a CANCEL command also in it.
  2. #12
    Aug 2005
    germany
    and another thing with popups.
    they didnŽt work inside the videoplayer skin.
    if you popuped an object, the skin goes to full solution and blocked all other grafics.
    if you ended the popup, the video screen will not be refreshed, so you have the rest of your popup graphic on the screen.
  3. #13
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The part about the popups in the video screen, that's a bit complicated already....little alone adding support for different popups... guess we'll see what mitch has to say
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #14
    Aug 2005
    germany
    hi blue,
    yeah i will wait what mitch says.
    i had a lot more questions
  5. #15
    MySQL Error
    Oct 2004
    yes, popups are complicated on video
    remember its not live!!
    the transparancy is done via a capture of the background, and may not even work
    right on top of video
    which is already a window ontop of rr
    so... i dont know what happens, but i wouldnt recomend to use them on top of video
    i would make a small popup and try
    as for the position data, im not sure, nothing is new about them, i dont doubt its hard to understand in skincommands.txt
    hopefully someone else will clearify
    the popup is modal
    if you want it to go away
    used the new idle
    this in the skin file
    IDL,10,"CANCEL"
    this will execute "CANCEL" command after 10 seconds of IDLE.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  6. #16
    MySQL Error
    Oct 2004
    Take a look at DFX5's DVD, the DVD MENU is a popup
    works quite well... and u will notice the transparency is a capture
    using MPCHC too
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #17
    Aug 2005
    germany
    Quote Originally Posted by mitchjs View Post
    used the new idle
    IDL,10,"CANCEL"
    hi mitch,
    its what iŽve coded. my question was, why did the videoplayer goes to fullscreen when i start a popup. and if the timer of the popup is ended, why i see a part of my popup in the preview-window. could the screen be refreshed.
    now i changed the command IDL,10,"CANCEL" into IDL,10,"CANCEL||Reloadscreen" and make my own refresh.
    also iŽam looking for a command to change between preview and fullscreen mode of the video player.
    the only way now is to lock it inside the setup against "AUTOHIDE"
    it would be nice if theres a command for skin coding.
  8. #18
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    mmmm is that battlestar there mitch ,,, origanal or the crap remake
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  9. #19
    MySQL Error
    Oct 2004
    origional of course!!!!!
    cant stand the new one!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #20
    MySQL Error
    Oct 2004
    Quote Originally Posted by GF-ler View Post
    hi mitch,
    im not sure what your asking
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. MicroXP splash screen popups
    By Lucifer in forum WinNT Based
    Last Post: 08-17-2008, 07:24 AM
  2. transparancy
    By holistic in forum Road Runner
    Last Post: 07-21-2006, 02:07 AM
  3. Web hosting with minimal popups/ads?
    By UnsanePyro in forum Off Topic
    Last Post: 01-16-2006, 09:26 AM
  4. taskbar popups
    By forevertheuni in forum WinNT Based
    Last Post: 02-13-2005, 06:17 AM
  5. [WinXP] How to disable loading settings popups
    By _wd in forum Software & Software Development
    Last Post: 11-19-2004, 03:30 PM
