Results 1 to 4 of 4
Thread: Embedding programs into RR
    Jan 2010
    Upstate NY
    I have been doing some extensive research the past few days on this subject. I can get a program to show up in my "Applications" menu, but the program "pops up" instead of being embedded. I have followed this guide to the best of my ability (admittedly, I dont understand the words "To set it up an Application on the Launch Folder:") I have been following the steps to add the program to the launch folder.
    The program im trying to embed is taskmgr.exe. Im guessing it "pops up" because it can not be re-sized or I am missing something. Any help is appreciated.
    Specs:
    Windows 7
    Skin: elite 1.6.6
    Car PC parts Purchased [90%]
    Car PC software Setup [80%]
    Car Audio setup [60%]
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Have a look at blues RRExtended plugin, he has incorporated the task manager into a custom list.
    http://www.mp3car.com/rr-released-pl...11-6-10-a.html
    may need a bit of skinning though
    Quote Originally Posted by Blue's RRextended Notes.txt
    = Task Manager Sect =
    Description
    This feaure will give you a listing of either the currently running process or a listing of all the visible windows.
    If in the process listing, you can get a LOT of extra info about the currently selected process.
    Kill one or several same named process.
    Close a selected window.
    Jump to the process that belongs to selected window in the window list.
    Ini Settings
    (rr.ini or skin.ini)
    TaskMgr_Enabled=True/False - tells plugin whether to gather the label info for the task manager feature upon plugin startup
    TaskMgr_Col1=xx - is the width in chars of the left part of the process list, defaults to 22 and can not be less than 13
    TaskMgr_Col2=xx - is the width in chars of the right part of the process list, defaults to 12 and can not be less than 12
    TaskMgr_DrvLstCol1=xx - is the width in chars of the Total size column of the drive info , defaults to 13 and can not be less than 13
    TaskMgr_DvrLstCol2=xx - is the width in chars of the Free size column of the drive info , defaults to 13 and can not be less than 13
    TaskMgr_DrvLstCol3=xx - is the width in chars of the Used size column of the drive info , defaults to 13 and can not be less than 13
    TaskMgr_CompIPs=True/False - sets wether the plugin gathers the computers IP and internet IP at startup, defaults to false.
    Required Skins
    Task_Manager.skin - Main feature screen
    Task_Manager_KillTask_Confirm.skin - Is called as a menu screen when the KillTask command parameter is executed, use the "Enter" cmd for OK/Yes button cmd on this screen
    Task_Manager_KillALLTask_Confirm.skin - Is called as a menu screen when the KillAllTask command parameter is executed, use the "Enter" cmd for OK/Yes button cmd on this screen
    Task_Manager_KillTask_Error.skin - Is called as a menu screen when a killed task can not be terminated
    Commands
    "TaskMgr"
    Syntax: "TaskMgr"
    Example: "TaskMgr"
    Result: Loads the "Task_Manager.skin", preloads the Custom list with processes, and sets the list title label
    "TaskMgr;KillSelected"
    Syntax: "TaskMgr;KillSelected"
    Example: "TaskMgr;KillSelected"
    Result: Loads the menu screen "Task_Manager_KillTask_Confirm.skin". Use "Enter" as the yes button cmd will auto exit out of screen.
    If able to kill task, will update the list, if not able to kill task, loads the menu screen "Task_Manager_KillTask_Error.skin"
    and gives reason why was unable to kill it.
    NOTE: WILL NOT KILL EITHER THE RoadRunner.exe or RideRunner.exe processes!
    "TaskMgr;KillAllTasks"
    Syntax: "TaskMgr;KillAllTasks"
    Example: "TaskMgr;KillAllTasks"
    Result: Same as above except that it will kill all process of the same selected name. Say you have 10 notepad.exe's open, using the above
    command (KillSelected), it will only kill the selected one, using this one (KillAllTasks) will kill all 10 notepad.exe processes.
    "TaskMgr_KillTask_Success"
    Syntax: "TaskMgr_KillTask_Success"
    Example: "TaskMgr_KillTask_Success"
    Result: Custom Event command that is fired when the killed task(s) have ended. Use this to display a Success message or like in the demo
    skin, just plays a sound letting you know that it completed w/o errors.
    "TaskMgr;Task/WinList"
    Syntax: "TaskMgr;Task/WinList"
    Example: "TaskMgr;Task/WinList"
    Result: Toggles the list between the running process list and the visible window list.
    "TaskMgr;Tasks"
    Syntax: "TaskMgr;Task"
    Example: "TaskMgr;Task"
    Result: Changes the list to the running process list, same as 'TaskMgr;Task/WinList' but is a direct command.
    "TaskMgr;Winlist"
    Syntax: "TaskMgr;Winlist"
    Example: "TaskMgr;Winlist"
    Result: Changes the list to the open windows list, same as 'TaskMgr;Task/WinList' but is a direct command.
    "TaskMgr;DriveList"
    Syntax: "TaskMgr;DriveList"
    Example: "TaskMgr;DriveList"
    Result: Changes the list to a drive info list'
    "TaskMgr;Refresh"
    Syntax: "TaskMgr;Refresh"
    Example: "TaskMgr;Refresh"
    Result: Refreshes the current listing.
    "TaskMgr;Info"
    Syntax: "TaskMgr;Info"
    Example: "TaskMgr;Info"
    Result: Populates all the "TaskMgrInfo_xxx" labels with the selected process properties.
    "TaskMgr;Go2Process"
    Syntax: "TaskMgr;Go2Process"
    Example: "TaskMgr;Go2Process"
    Result: Used with the window list showing, takes you to the process list and selects the process that the selected window belongs to.
    "TaskMgr;RunProcess"
    Syntax: "TaskMgr;RunProcess"
    Example: "TaskMgr;RunProcess"
    Result: Used with directory list and runs the selected file.
    "TaskMgr;RefreshCompInfo"
    Syntax: "TaskMgr;RefreshCompInfo"
    Example: "TaskMgr;RefreshCompInfo"
    Result: Updates all the computer/system labels.
    Labels
    "TaskMgrInfo_Name"
    Example: L,xxx,xxx,xxx,....,"TaskMgrInfo_Name",""
    Result: Shows the long file name of the selected process
    "TaskMgrInfo_MemUsed"
    Example: L,xxx,xxx,xxx,....,"TaskMgrInfo_MemUsed",""
    Result: Shows how much memory the selected process is using. Same as the right side of the process list.
    "TaskMgrInfo_Priority"
    Example: L,xxx,xxx,xxx,....,"TaskMgrInfo_Priority",""
    Result: Shows the process's CPU priority, using one of the following: N/A, Low, Below Normal, Normal, Above Normal, High, Real Time
    "TaskMgrInfo_ExeSize"
    Example: L,xxx,xxx,xxx,....,"TaskMgrInfo_ExeSize",""
    Result: Shows the size of the process's file size
    "TaskMgrInfo_ProcUptime"
    Example: L,xxx,xxx,xxx,....,"TaskMgrInfo_ProcUptime",""
    Result: Shows how long the process has been running for in a "x Days x Hrs x Mins" format
    "TaskMgrInfo_Path"
    Example: L,xxx,xxx,xxx,....,"TaskMgrInfo_Path",""
    Result: Shows the full path of the process
    "TaskMgrInfo_CmdLine"
    Example: L,xxx,xxx,xxx,....,"TaskMgrInfo_CmdLine",""
    Result: Shows the command used to start the process
    "TaskMgr_CpuName"
    Example: L,xxx,xxx,xxx,....,"TaskMgr_CpuName",""
    Result: Shows the Name of the CPU
    "TaskMgr_CpuMaker"
    Example: L,xxx,xxx,xxx,....,"TaskMgr_CpuMaker",""
    Result: Shows the Manaufacture of the CPU
    "TaskMgr_CpuStatus"
    Example: L,xxx,xxx,xxx,....,"TaskMrg_CpuStatus",""
    Result: Shows the CPU status..I'm thinking that if its not good, you won't won't have to worry about what this might display
    because you probably have a blank screen...hehe
    "TaskMgr_CpuMaxSpeed"
    Example: L,xxx,xxx,xxx,....,"TaskMrg_CpuMaxSpeed",""
    Result: Shows what the CPU is currently running at.. "733 Mhz" or "7.98 Ghz"
    "TaskMgr_CompUptime"
    Example: L,xxx,xxx,xxx,....,"TaskMrg_CompUptime",""
    Result: Shows how long since computer was last turned on, in a "x Days x Hrs x Mins" format.
    "TaskMgr_CompIP"
    Example: L,xxx,xxx,xxx,....,"TaskMrg_CompIP",""
    Result: Shows your computers IP address if connected to a network.
    Rely's on ini setting "TaskMgr_CompIPs" above, defaults to off and shows "Disabled"
    If no enabled connecion is found, then it shows "No Network Adapter Detected"
    "TaskMgr_WANIP"
    Result: Shows your internet IP address if connected to a network.
    If no comp IP, then shows "No Inet Detected"
    "TaskMgr_HomeDrive"
    Example: L,xxx,xxx,xxx,....,"TaskMrg_HomeDrive",""
    Result: Shows what drive OS is on. ie.."C:" or "D:"
    "TaskMgr_HDrvTotal"
    Example: L,xxx,xxx,xxx,....,"TaskMrg_HDrvTotal",""
    Result: Shows the total capacity of the home drive. ie.. "2.25 Gb" or "500 Mb" or "999 Kb"
    "TaskMgr_HDrvFree"
    Example: L,xxx,xxx,xxx,....,"TaskMrg_HDrvFree",""
    Result: Shows the total free space left on the home drive. ie.. "1.25 Gb" or "350 Mb" or "900 Kb"
    "TaskMgr_HDrvUsed"
    Example: L,xxx,xxx,xxx,....,"TaskMrg_HDrvUsed",""
    Result: Shows the how much is used on the home drive. ie.. "1.25 Gb" or "350 Mb" or "414 Kb"
    "TaskMgr_DrvInfo;<DRIVE LETTER>;<"FREE","TOTAL","USED">"
    Example: L,xxx,xxx,xxx,....,"TaskMrg_DrvInfo;E;Free",""
    Result: Shows the how much free space left on the "E" Drive. ie.. "5.75 Gb" or "214 Mb" or "30 Kb"
    Indicators
    "TaskMgr_ListProcess"- Shows that the list is a process listing
    "TaskMgr_ListWindows"- Shows that the list is a window listing
    "TaskMgr_ListDrives"- Shows that the list is a drive info listing
    Jan 2010
    Upstate NY
    Quote Originally Posted by Enforcer View Post
    I have not. However, once I learn how to embed single programs, I will take a look. Learning how to embed a program is my main goal of embedding the task manager, not being able to use the task manager.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    In that case just start with trying to embed notepad.
    The main thing about embedding is to get the window name correct. Without this it will always end up on top and not embedded.
  1. Programs
    By diggla in forum Newbie
    Last Post: 12-28-2007, 12:56 PM
  2. Embedding systray programs
    By TSXPC in forum Centrafuse
    Last Post: 09-20-2006, 09:34 PM
  3. What skinning Programs do you use to skin your programs?
    By bry21317 in forum Software & Software Development
    Last Post: 01-12-2005, 03:26 AM
  4. To all of you who use P2P programs....
    By Seth in forum Off Topic
    Last Post: 08-13-2004, 01:16 AM
  5. Programs for DOS
    By neli_boy1 in forum Software & Software Development
    Last Post: 07-27-2002, 12:48 AM
