Results 1 to 10 of 15
Thread: Problem DELETEFILE,RENAMEFILE in skin with MENU command
    Oct 2010
    Ivry-Sur-Seine (France)
    I have the same problem as liquid_smoke in this thread (http://www.mp3car.com/rr-bug-tracker...u-command.html), I tried the commands Guino offers but without success.
    Do you have another way?
    Thanx
    MySQL Error
    Oct 2004
    again, those commands are Directory List required skins
    you provide NO useful information to even begin to help
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Basically the pop up needs to have a directory list in it to know what to delete or rename.
    Oct 2010
    I use directory list in my skin.
    Here a part code of my skin :
    [Buttons]
    B01,7,241,101,54,, <-(Command send by the exectbl via setbuttonid because i use this skin for delete,rename,load,save ...)
    B02,127,241,101,54,"Menu;JumpToLetter.skin",
    B03,247,241,101,54,"CANCEL",
    [Liste]
    IL,DL,RGBFF00FF,RGBFF00FF,***************,0,50,60
    S01,7,7,341,231,128,255,128,000,000,000,255,255,25 5,255,255,255,128,255,128,000,000,000,TRUE,12,"Dig iface"
    Here a part code of my exectbl.ini:
    "MANAGEDEL","MENU;AUDIO_PLAYLISTMANAGE.SKIN||SETPA TH;$PLAYLISTPATH$||SETVAR;VARMANAGE;Effacer||SETBU TTONID;B01;DELBUTTON"
    "MANAGEREN","MENU;AUDIO_PLAYLISTMANAGE.SKIN||SETPA TH;$PLAYLISTPATH$||SETVAR;VARMANAGE;Renommer||SETB UTTONID;B01;RENBUTTON"
    "DELBUTTON","EXIT||DELETEFILE"
    "RENBUTTON","EXIT||RENAMEFILE"
    I hope you have the information needed to help me.
    Thanx
    MySQL Error
    Oct 2004
    once you do menu.. the DL has to be on the AUDIO_PLAYLISTMANGE.SKIN
    and no one here can tell what context your in with just snips like that
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Oct 2010
    Ok, you could find in attachment audio_playlistmanage.skin and exectbl.ini.
    Thanx
    Attached Files Attached Files
    MySQL Error
    Oct 2004
    how about the images for this popup
    ---------- Post added at 09:33 AM ---------- Previous post was at 09:27 AM ----------
    also your logic dont make sense to me
    what command do you use to use this skin?
    i dont see how this is going to do anything useful...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Oct 2010
    I use the command MANAGEREN (in the case of renaming) and MANAGEDEL (in the case of a deletion) from exectbl with a button in audio_playlist.skin.
    My logic is to use this skin for several functions (save, load, delete, rename, ...) to avoid the multiplication of similar skins.
    I provided a rar with images and skins.
    MySQL Error
    Oct 2004
    ok, FYI delete file only works on DL
    your audio_playlist screen as it should has a PL
    so deleting from the PL isnt allowed, and it would muck up the PL, as technicall you have to remove and item..
    i know what you want to do... but deletefile is ment to come from a DL (directory list)
    not to mention Playlists dont usually have filenames
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Oct 2010
    ok, thank you very much for your help.
    So I will change the command MENU by LOAD and redo my pictures.
  1. Skin command on skin load?
    By jrtf83 in forum RR Skins
    Last Post: 12-07-2006, 05:49 AM
  2. Close menu once command is clicked?
    By HyperSprite in forum Road Runner
    Last Post: 11-27-2006, 06:05 PM
  3. DELETEFILE dosnt work on .skin using MENU command
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 10-04-2006, 03:13 PM
  4. Help with MENU command
    By 01black_ac in forum Road Runner
    Last Post: 05-15-2006, 02:19 PM
  5. Destinator: Map Monkey Menu command
    By MatrixPC in forum RR Skins
    Last Post: 05-07-2005, 12:53 PM
