Results 1 to 10 of 12
Thread: maximum flash movies inside a skin
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    there seems to be a problem in RR regarding the number of flash objects loaded in the skin.
    I am trying to add 4-5 flash swf's in mostly all the .skins in a skin, the thing is that in some .skins the flash won't update, seems like RR is not updating the labels..and/or the swf's appear frozen or won't even appear, it happens like in 2-3 out of 15-20 .skins.. and on a restart it might happen to another .skin, not always the same..
    I have tried changing the swf's with other swf's but that did not help..
    The flash objects are not intensive at all.. they are realy just for displaying some labels indicators etc.
    i tried older RR versions back to January, but all behave the same
    it seems 3 swf's in a .skin is the maximum number without any problems
    MySQL Error
    Oct 2004
    keep in my rr doesnt draw or run the flash, thats all handled by adobe... so it could be issue with 1, your .swfs or flash itself
    there is no limit to swfs put in by RR
    and once rr sets the movie name to the object, RR is basically done with it
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Nov 2004
    St Louis
    Quote Originally Posted by Nomader View Post
    I have seen much the same in one of my skins, too. Not nearly as often on the "non-appearing," but the freezing of RR happens to me about the same regularity as you stated. I assume (there's that danger word) that it has to do with my video driver/memory. Could also be my CPU (1.2G Dual Core), but I don't think so - CPU usually hovers at 54%.
    I have also found that the order that they load makes a difference. Labels that feed flash object need to be early in the .skin. Flash that reads internet info should be last; graphic intensive should be next to last; and ones with the least updates go first.
    I don't know of a limit to the amount if flash RR can handle. I currently have 9 flash objects in this skin:
    As a last ditch effort, you may want to spread them out in the skin file so they don't all load at the same time, i.e., flash/buttons/flash/labels/flash/lists/flash/buttons/flash/images/etc, etc, etc. Lastly, how many plugins are you running and is the flash object dependent on them? That may also have an effect on whether a flash loads.
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    I run about 20 swf per skin, mostly without problem...they are small animated buttons/indicators/status swf's....check out my flashflex skin in my sig...
    Mar 2008
    Toronto Canada
    Oh damn! I forgot to mention! Sometime last year Adobe released an update to Flash that totally borked my flash components....try an older veresion of flash, like 12-15 months ago....
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Adobe..Last year...update... I get that nice Flash updater at least once a month or so...one has to keep current when using third party SW, unless you like to find ones creations broken for no apparent reason..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    MySQL Error
    Oct 2004
    there is a possible total flash limit, but I'm still not 100% sure, its about 30 movies, without further testing i cant say for sure
    this isn't a RR limitation, its just a flash activex limitation.. but I'm still not 100% convinced
    and as blue said, i keep updated as adobe pushes them on me, and find no issues, it just gets better with their hw accelleration on h264 videos
    (non rr stuff, but sill important to me)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2012
    Germany - Munich
    does it mean, i have to downgrade to an ealier adobe flash version and it works?
    MySQL Error
    Oct 2004
    dont know, dont think downgrade will help... there just is a limit
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2012
    Germany - Munich
    so i must convert all my buttons to png-file without animation.
    i asked google a long time. -> no results.
  1. Replies: 4
    Last Post: 11-29-2006, 01:57 PM
  2. Replies: 20
    Last Post: 06-22-2005, 10:02 AM
  3. Making my own skin - Preview Inside
    By icet in forum FrodoPlayer
    Last Post: 01-20-2005, 08:29 AM
  4. SWF / Flash Movies
    By tbird2340 in forum FrodoPlayer
    Last Post: 11-24-2004, 10:09 PM
  5. First skin for 1.0.9 - inside
    By ernie in forum FrodoPlayer
    Last Post: 10-24-2004, 11:07 AM
