Results 1 to 10 of 20
Thread: RideRunner COMMAND
    Mar 2011
    RideRunner COMMAND
    Would know someone help me find a command that starts an application which has already started (automatic execution) without me open another process?
    MySQL Error
    Oct 2004
    the wording you got is funny
    start an application that is already started... that alone dont make sense
    its in most cases up to the application, if it runs in more than one instance, some allow, some dont
    if you want to embedd an app that is already started.... "run;;;windowname"
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Mar 2011
    Quote Originally Posted by mitchjs View Post
    I do not understand what's so funny?
    if I have a software startup that goes in and I want to draw in the RR can not I?
    With the RUN command opens another process and I am certainly not an optimal solution.
    Learn about the commands minimizes maximizza ...???? or you can go to laugh ..
    MySQL Error
    Oct 2004
    the run example, i gave, DOES NOT start another process
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mar 2011
    minimize maximize..
    it's impossible another command..
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Carlo, what he meant by "funny", is not translating well. Funny = strange, unusual, not translating well. The translation is not very good to English, and it is hard to understand exactly what you are asking.
    Try posting the question in your native language, and I will see if I can translate it a little better, or get a friend to translate it for me.
    I think I may know what you are asking.... Do you mean you start your GPS, or another program, when the computer starts, and then you want to show it in RR when you go to the screen? If this is the case, then you can still use the Run command, as RR will see that it is already running, and will not start the program again, it will just embed it in to the skin.
    My Fiero Build Thread
    Mar 2011
    Quote Originally Posted by JohnWPB View Post
    Ciao allora posto il mio problema nella mia lingua madre sperando di non essere bannato.
    Praticamente avendo un software che Ŕ in esecuzione automatica non saprei come sarebbe possibile richiamarlo in una skin di RR.
    Io vorrei un comando che all'apertura di questa skin mi maximizza questo software. il comando RUN non Ŕ utilizzabile perchŔ non richiama il programma aperto ma avvia sempre nuovi processi..
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    No, you are not going to be banned for asking a question
    Ok, if RR is running a secons instance with the RUN command, then you need to make sure you have the correct window title. If the window name is wrong when you use the RUN command, RR will load another instance. RR looks for the name of the window, and not the system process of the exe.
    In Italian:
    No, non stanno per essere bannato per porre una domanda
    Ok, Ŕ necessario assicurarsi di avere il titolo corretto finestra. Se il nome della finestra Ŕ sbagliato quando si utilizza il comando RUN, RR caricherÓ un'altra istanza. RR cerca il nome della finestra, e non il processo di sistema del exe.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Although Mitchjs will be if he edits a quote in another persons post again.
    (even if it was him that was quoted)
    Mar 2011
    In Italian:
    Io mettendo il comando RUN mi apre un'altra istanza.. ecco il comando che assegno al bottone "RUN;C:\Program Files\CONSOLE\Console1.exe"
    non me lo richiama ovvero maximizza, ma mi apre un'altro processo..
  1. RideRunner for Android?
    By upspace in forum Road Runner
    Last Post: 09-24-2014, 02:20 PM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
  4. Riderunner issue with XM
    By chgrec in forum Road Runner
    Last Post: 04-22-2009, 07:26 PM
  5. Replies: 4
    Last Post: 12-14-2008, 07:55 PM
