Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: RR 04-01-2011 Release
    MySQL Error
    Oct 2004
    OMG APRIL!
    Download HERE
    Some Highlights:
    • Media Player Classic - Home Cinema Fully supported
    • New Commands; RREXIT, OSKAPPENDTEXT, CHAPTERMENU
    • New Events ONMINIMIZED, ONRESTORED
    • Plugin SDK; AddRepeatCMD Method
    PLEASE READ HISTORY!!!
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    3/20/2011
    + Events: ONMINIMIZED, ONRESTORED;  fired after RR is minimized or restored via cmds or taskbar
    3/19/2011
    * Minor Tweak to Video File Browser ("Video_Browser.skin") so that video files
      arnt treated as audio files.
    # Tweaked video end detection, begin next item playback in the video playlist fixed
    3/17/2011
    + Skin Command; "OSKAPPENDTEXT;text" Appends text to curent OSK TextBox (must be visable)
      ex: K,654,360,148,59,000,000,000,"OSKAPPENDTEXT;.com"
    * Skin Command; "DELETE" command for OSKs deprecated, use "DEL" instead
    	ex: K16,000,525,124,69,000,000,000,"DELETE" now is K16,000,525,124,69,000,000,000,"DEL"
    	This removes the ambiguous use of "DELETE" and tied to a skin named starting with "osk" or "numosk"
    	Works more like "backspace" and "space" does now.
    3/17/2011
    + Plugin SDK; c#: AddRepeatCMD(string command) vb6: AddRepeatCMD(command as string)
        This is for plugin designer/programmers, if they want to add a command that when press and held repeats like "VOL+" and such
        Example: AddRepeatCMD("plg_godown")
        Now this is added to the list of repeatable commands.
    3/13/2011
    + Skin Command; "RREXIT" will exit RR from anywhere
    3/8/2011
    * Improvement in Web Browser embedding.
    # When RR is restored from minimize while on wbrowser.skin, browser is now restored.
    3/7/2011
    # Last character was lost on a label wrap and no space to wrap at.
    + Skin Command; "DELETEFILE" now will work on Playlists, it will perform a "MINUS1"
      to remove the item from the playlist, and then delete the actual file.
    + Skin Command; "SENDWMCOMMAND;windowname,lparam;wparam"
      windowname can use format of !classname!windowame
    3/6/2011
    + New Video Player; MPCHCVidRR Player
      Uses Pilot API in MPC-Home Cinema, must use special build of mpc-hc, till
      MPC-HC team incorpates patch file, supplied to them to fix 3 issues in DVD playback in
      Pilot mode, if you using another version, control will work, just during DVD playback
      no timecounters will change.
      Example in RR.ini:  videoplayer=MPCHCVidRR
                          mpcpath=C:\Program Files\RideRunner\mpc-hc.exe
                          dvdplayer=MPCHCVidRR
    3/5/2011
    - MPCVidRR Player; removed extra support of MPC-HC
    - MPCVidRR Player; remove full screen mode, because of bugs in mplayerc.exe with its webserver
    + Skin Command; "CHAPTERMENU" (implemented in MPCHCVidRR & MPCVidRR)
        Requests the chapter menu on the DVD (some DVDs have it, some dont)
    3/4/2011
    ! fixed up support for dvd_player.skin and the "DVD" command
      "DVD" will 1st look for "dvd_player.skin" if not found, it will use
      "video_player.skin"
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    thanx guys for the release..great work.
    Sep 2006
    Yippie fixed the "next" for videos Can't wait! Thanks guys!!!
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I can't wait also
    Jul 2010
    Thank you! I will try it tomorrow.
    I love to use fennec web function, the scolling is similar as using an ipad (love it) . However, I found it some issues such as: do not support flash (Thus I can't play any online music website or youtube), did not support virtual keyboard, i have to have an actual keyboard to put the website link.
    Can you fix these issues on the next release please? And I don't know how to use firefox or IE instead of Fennec. I change the RRconfig, it still uses the Fennec engine when running browers.
    MySQL Error
    Oct 2004
    we dont offically support fennec... i can only tell you to try my IE Web browser plugin i did, its in the APPMART
    i cant tell you what you did to enable fennec.. as i know little to nothing about it
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Just going on a whim here, but I could assume that he's using one of the DFX skins, as we include the fennec browser in the skin. And yes, it does not support flash yet, would be nice if it did though and a built in OSK....we can only dream till then.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jul 2010
    Bingo, yep, I did use DFX skin. Your skin is all I need for a carpc frontend. I try to use other web browser such as firefox or ie however, it still using fennec. As I said, I love to use fennec, but without flash, i don't have any reason to use web browser cause I use web browser for music online or youtube.
    Anyway, thanks for your advice, I hope you guys keep doing your very good job. I myself very appreciate what you did to carpc community.
    Apr 2006
    Greece
    Quote Originally Posted by yd82 View Post
    me too, i appreciate all the work that has been done
    Nov 2004
    St Louis
    Quote Originally Posted by Nomader View Post
  1. Replies: 161
    Last Post: 06-27-2011, 09:12 AM
  2. Replies: 21
    Last Post: 04-01-2011, 08:59 AM
  3. RR 02-01-2011 Release
    By mitchjs in forum Road Runner
    Last Post: 02-22-2011, 04:46 PM
  4. upgraded to 2/1/2011 and...
    By tundra2000 in forum Road Runner
    Last Post: 02-17-2011, 04:08 PM
  5. Ces 2011???
    By Sonicxtacy02 in forum MP3Car Gatherings
    Last Post: 01-19-2011, 08:08 AM
