Results 1 to 8 of 8
Thread: setsource and activesource not working with custom source
    Low Bitrate rtgree01's Avatar
    Aug 2007
    STL
    I'm trying to change the source to the sirius input. From the documentation, I believe that the correct code is
    Code:
    SETSOURCE;SIRIUS
    The issue is that I don't have the proper sirius device. I have found a way to control the oem sirius radio in my car. Everything works great, but I can not get the activesource or activesourceid to change to sirius. I do have a Directed HD radio, and I can setsource to the radio. I can also setsource to audio.
    I am attempting to write a skin that depends on determining which audio source is active. So without this capability, I am stuck.
    Any idea what I have to do to make RR think I have a Sirius device connected?
    Thanks,
    Ryan
    MySQL Error
    Oct 2004
    Sirius assumes you going to use RR's native Sirius control, which it seems you are not... so.. it will not work...
    your are way out side the box
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by mitchjs View Post
    I bet your forum subtitle "MySQL Error" must drive the perfectionist in you nuts lol
    Live mp3Car Facebook Chat
    MySQL Error
    Oct 2004
    bah, never noticed
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2007
    STL
    heh...
    I know that I am definitely outside the box....
    I'm guessing that RR is uninterested in allowing custom audio sources (whether by plugin or other means).
    So I'm going to try to find a workaround...
    If I can't figure something out with RR, I'm going to have to look into other options. No offense... I just think that my setup may not be compatible. That sucks because there has been a lot of cool things with it...
    Thanks!
    Ryan
    MySQL Error
    Oct 2004
    its not that rr isnt interested in custom audio sources, its just a very complicated matter...
    nor in most cases is haveing "setsource;customsource" practical
    even in this case here a fail to see the purpose
    course stopping the active source is prob all you want... but you didnt provide any real info on what you are trying to achive
    like i said you are outside the box
    i can help you and even make additions to rr, but i need a clear path of achivement
    and then translate that into code
    i have considered custom sources, but quite frankly no one has asked, the last source i added, DVB, prob 5 people in the world use
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2007
    STL
    Mitch... thanks for keeping me honest... I haven't described exactly what's going on....
    I agree, custom audio sources can be complicated.
    I'll describe my situation.
    I am able to control my car's built in amplifier, steering wheel controls, and sirius radio via the CAN bus. I have removed my head unit and replaced it with a touchscreen monitor, atom based pc running xp, and a microcontroller that interfaces to the car's CAN bus.
    I have developed a RR plugin that emulates everything that the head unit used to do with respect to the CAN bus. I'm now trying to make things pretty with the skin I'm using... I obviously have to modify any skin that I want to use to support my new plugin. I like the look of Elite Wings... but I'm also working on one from scratch.
    I would like to have RR start, and based on a setting stored in the skin, bring up the last audio source. If it was HD Radio, it'll bring up the radio page... If it was MP3 audio, the audio page should come up... Since I can't set RR to Sirius, I can't bring up the Sirius page when starting RR. Also, depending on what source is active, different labels and images should be displayed. Then there is also the ONSOURCECHANGE event that can be handy for a number of reasons. I also would like for the mixer line to mute and unmute the appropriate audio sources.
    I can do a lot of things from within my plugin, and I'm not against it, but it doesn't seem to be the "right" way to do it. For my day job I often have to "find a way" to make things work... so I am not afraid of it... but I like elegant solutions.
    I can think of a few different paths forward....
    1) Make things work from within my plugin
    2) Work with Mitch or Guino to "hijack" the native RR sirius device
    3) Work with Mitch or Guino to add "my" sirius device
    4) Go with another front end
    I'm not sure which path I like best... there are drawbacks to all of them...
    I don't want to make anyone do a lot of work that would only help me... If we were to work on changing RR, I'd prefer to make a generic solution so that everyone can benefit. I'd love to help design it too, but if it's not in the RR development path, I understand.
    Again,
    Thanks for everything!
    Ryan
    MySQL Error
    Oct 2004
    well...
    i can telll you #4 isnt a real option, you will find that out all too quickly, only chance would be OpenMobile... and thats because its very open, but you would be coding alot, it also does about 1/8 or less of what RR does today.
    #2 you could do that, if you did your own siriuscomm.dll that followed existing interface (need to be a good programmer)
    #3 maybe, but too niche
    #1 you could be doing alot now in your plugin... all commands pass thru, so you could react or modify them...
    what you cant do is stop other audio sources cleanly (till yesterday,pm me)
    generally when starting RR, it DOES not go directly to the "source page" it goes to the "menu.skin" ill be it with the last source started(ie. radio, audioplayer, sirius, xm)
    course you can make a command run, which sends it to the screen, "radio"
    your sirius is just ur own command your plug does
    like
    "mysirius"
    and that loads the skin mysirius_player.skin or what not...
    all you need at that point, it to stop any "players/audio sources" and switch yours on...
    and when rr goes to say audioplayer, stops yours
    i have some ideas right now in my head to do a clean "custom source"
    this is beyond the scope of this forum, please PM me and ill give you contact information
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. MKIV Supra TT - Mac Mini / Custom Dash / Custom Boot
    By tresseh in forum Show off your project
    Last Post: 01-18-2012, 05:35 PM
  2. Where to source wire for custom cables?
    By colin in forum General Hardware Discussion
    Last Post: 11-25-2009, 03:12 PM
  3. SKIPTO Not working correctly with Custom Lists
    By JohnWPB in forum RR Bug Tracker
    Last Post: 02-14-2008, 09:14 AM
  4. FS: Custom 1 Din Solution Mazda RX-8 and custom CarPC
    By Boxcar in forum Classified Archive
    Last Post: 03-06-2006, 10:02 AM
  5. '93 Opel Vectra A - Custom Dash & Custom Case
    By zvi in forum Show off your project
    Last Post: 10-18-2005, 08:36 AM
