Results 1 to 3 of 3
Thread: BYVARX question
    Nov 2006
    BYVARX question
    I get the following on the latest RR release:
    Code:
    4/24/2011 01:01:03 PM: EXECTBL Translation: MBGM_AGAIN -> BYVARX;GMFromQuery;(SETVAR;GMFromQuery;0||SENDMSG;RRDataEntry;GMapSearchData<<SETVAR;GMFromQuery;0||SENDMSG;RRDataEntry;ASSearchData)
    4/24/2011 01:01:03 PM: Executing: BYVARX;GMFromQuery;(SETVAR;GMFromQuery;0
    4/24/2011 01:01:03 PM: BYVARX Syntax Error, missing closing parenthesis
    4/24/2011 01:01:03 PM: Que Exec: True, gsmaps.skin, "SENDMSG;RRDataEntry;GMapSearchData<<SETVAR;GMFromQuery;0||SENDMSG;RRDataEntry;ASSearchData)", False
    4/24/2011 01:01:03 PM: Executing: SENDMSG;RRDataEntry;GMapSearchData<<SETVAR;GMFromQuery;0
    4/24/2011 01:01:03 PM: Que Exec: True, gsmaps.skin, "SENDMSG;RRDataEntry;ASSearchData)", False
    4/24/2011 01:01:03 PM: Executing: SENDMSG;RRDataEntry;ASSearchData)
    4/24/2011 01:01:03 PM: Leave Exec: False, gsmaps.skin, SENDMSG;RRDataEntry;ASSearchData), False
    To me my BYVARX code looks just like the example from which it was copied and modified but then again at my age I could be seeing things.
    Regards,
    Jim
    MySQL Error
    Oct 2004
    when i run that byvarx though, no issues
    but what is says is executing is invalid...
    4/24/2011 01:01:03 PM: EXECTBL Translation: MBGM_AGAIN -> BYVARX;GMFromQuery;(SETVAR;GMFromQuery;0||SENDMSG; RRDataEntry;GMapSearchData<<SETVAR;GMFromQuery;0|| SENDMSG;RRDataEntry;ASSearchData)
    could be related to the exectbl translation, i have no idea
    ---------- Post added at 07:27 PM ---------- Previous post was at 07:23 PM ----------
    yes.. thats why... im looking at the translation process...
    im sure its trying to break up the command early
    ---------- Post added at 07:30 PM ---------- Previous post was at 07:27 PM ----------
    yep... its working as programmed, and as designed
    a command
    "TEST,"blablabla||foobar"
    would get split up...
    i know thats not what you want here.. but its how its working
    dont use exectble, and it wouldnt happen
    im looking to see if i can prevent it
    ---------- Post added at 07:51 PM ---------- Previous post was at 07:30 PM ----------
    test build available at the usuall location...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Nov 2006
    Problem solved.
    Regards,
    Jim
  1. Sound outputs question and LCD question
    By davidj2k in forum Newbie
    Last Post: 02-16-2009, 08:25 AM
  2. 4 channel amp question & line/preamp question.
    By Profozone in forum Car Audio
    Last Post: 08-18-2007, 02:52 PM
  3. Power Question/Setup Question, minibook pc
    By seamonkey420 in forum Newbie
    Last Post: 05-17-2004, 10:47 PM
  4. Easy head unit question, and PC to amp question.
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-09-2001, 04:57 PM
