Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: RR and Network hosted playlists.
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I have a new setup of RR in my house using it as a music player with an in wall touchscreen. All my music in my home is stored on a server. On the RR Local machine I mapped network drives and music plays fine. The issue I have is when I create play lists and then try to play them RR starts cycling down through all the songs but not playing the as if there were missing files. What is the limitation I am running into with the music files not being stored locally in this case?
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    maybe more details like, skin?, player?, m3u file?
    MySQL Error
    Oct 2004
    how u creating the Playlists????!?!?!?!?!?!?!?
    winamp will only save the minimum required to get the music for winamp!
    so.. if u made a PL, and moved winamp or moved music... it will usually fail
    so.. look at ur m3u file.. and fix it
    RR will try to figure it out, but if its radically different it will fail
    course if u make the PL inside RR, by adding songs manually, and saving the list... winamp will save it out
    and it should be working play list as long as nothing moves...
    one of the strange things that winamp does!!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Nov 2007
    PA
    I apologize, my PC got a corrupt Boot Manager and I am just able to get back on. I am using RR 5/1/11 with DFX5 on WIN7 32bit. This is my first go with RR and Win 7, In the car I use Xp but in this indoor use of RR I am not using anything other than music, so figured maybe I wouldn't have any issues. I tried creating the play lists both in Winamp (latest version) and in RR. They are .m3u files. I have tried saving the m3u to both a local folder and a network folder and same issues arise. RR cannot seem to load the play list when the Files themselves are stored on a network dirve.
    MySQL Error
    Oct 2004
    like i said... take a look at the m3u file...
    its not RR that cant find the music... its winamp
    (yes to some extent rr wont find it to get tags)
    but with out any real details of the m3u file and your file system, its all abstract and no one can solve your issue
    but you
    also it has to be a mapped drive
    like M:
    ---------- Post added at 06:00 PM ---------- Previous post was at 05:59 PM ----------
    if u moved the music... the m3u file is basically invalid now
    ---------- Post added at 06:00 PM ---------- Previous post was at 06:00 PM ----------
    just one problem with winamp and its m3u's
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Nov 2007
    PA
    It is a mapped drive and is exactly M. File system is just network storage with typical folder structure. Artists/Album/Song etc..Im not liking the whole WIN 7 and RR experience right now. Might have to slap XP on the machine and start over. Lots of issues, mostly between the skin though. Also, SKIN folder is not located within RideRunner main directory. Is it an change in RR or did something happen there?
    MySQL Error
    Oct 2004
    ugh!
    why do u keep avoiding what im telling you!
    LOOK at the CONTENTS of the m3u file, open it in a text editor
    hell, if i knew what its contents was i could help, but i dont, cause your keeping that to your self
    ps... there are NO KNOWN issues with RR and WIN7
    my suggestion, is UAC off in the carpc... home pc... uac on (unless your good with pcs, and know what ur doing, which i assume you do, then UAC off is fine)
    ---------- Post added at 06:24 PM ---------- Previous post was at 06:19 PM ----------
    ill post my own example...
    inside m3u
    \MyMusic\Rush\2112\2112.mp3
    ok, with that winamp says the song must be on the SAME drive a me (me = winamp.exe)
    winamp installed at C:\Program Files\Winamp\Winamp.exe
    so the song must be at
    C:\MyMusic\Rush\2112\2112.mp3
    well.. if its in M: as in M:\MyMusic\Rush\2112\2112.mp3
    clearly winamp isnt going to find it, yet alone anything... its HOW WINAMP WORKS!!!
    i dont like it, but thats how the winamp people chose to do it
    to fix add the full path in the m3u
    or REMAKE EVERYONE OF YOU M3Us (daunting task) course i dont use playlists so to me no biggy
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Nov 2007
    PA
    UAC is off.
    Here is a snip of one of the M3U's
    #EXTM3U
    #EXTINF:201,Dierks Bentley - Free And Easy (Down The Road I Go)
    \\DOUGSERVER\Networked Music\Dierks Bentley\Greatest Hits - Every Mile A Memory\01-dierks_bentley-free_and_easy_(down_the_road_i_go).mp3
    #EXTINF:222,Dierks Bentley - Trying To Stop Your Leaving
    \\DOUGSERVER\Networked Music\Dierks Bentley\Greatest Hits - Every Mile A Memory\02-dierks_bentley-trying_to_stop_your_leaving.mp3
    #EXTINF:289,Dierks Bentley - Sweet & Wild
    \\DOUGSERVER\Networked Music\Dierks Bentley\Greatest Hits - Every Mile A Memory\03-dierks_bentley-sweet_and_wild.mp3
    #EXTINF:282,Dierks Bentley - Come A Little Closer
    \\DOUGSERVER\Networked Music\Dierks Bentley\Greatest Hits - Every Mile A Memory\04-dierks_bentley-come_a_little_closer.mp3
    #EXTINF:228,Dierks Bentley - How Am I Doin'
    I really think my issue now is Winamp related. I don't know why but through trying to diagnose an issue, upon returning to winamp all media from the library is gone. I must have network issues. I know the PC has full read/write access to the server but something is wrong there. I'll be moving in that direction now. Thanks a lot!
    Jun 2008
    Perth, Western Australia
    1) Those are UNC paths, not mapped drive paths. so even if the drive is shared, its still trying to access the server via the network route, not your mapped drive. You need to delete the \\DOUGSERVER from each line, and replace it with M: which is dead easy to do in notepad, just to a search/replace, use the find field as \\DOUGSERVER, and the replace with as M:. Should clear up that issue, and convert them over to using the mapped drive.
    2) You have spaces in all those directories, try having " marks at the start and end of each filename, its possible that its only looking for a file called (In the example above):
    And getting lost there. Try it with " marks, so it looks like:
    "\\DOUGSERVER\Networked Music\Dierks Bentley\Greatest Hits - Every Mile A Memory\03-dierks_bentley-sweet_and_wild.mp3"
    So copy the m3u file so you have a backup, trim everything bar about 3 or 4 files out of it (makes it easier to test with), and try the above two changes, see how you go. If it works, then do the same to the full length m3u file.
  1. Anyone need their skin or car computing related apps hosted for download?
    By lukec in forum Software & Software Development
    Last Post: 05-31-2008, 11:50 AM
  2. Replies: 9
    Last Post: 01-18-2008, 08:33 PM
  3. New Skins Hosted!!!
    By monger in forum Auto-Play
    Last Post: 01-05-2003, 08:01 PM
  4. Replies: 11
    Last Post: 10-16-2001, 09:50 AM
