Page 9 of 9 FirstFirst 123456789
Results 81 to 87 of 87
Thread: RR 5/1/2011 > foobar2000 Player notes
  1. #81
    Jan 2010
    I don't know how it works now but I know that a year ago RR didn't receive an actual track list from Foobar but it only knew which tracks it passed to Foobar.
    With .cue lists this method doesn't work properly because one .cue file is extracted by Foobar in a lot of tracks.
    So I was forced to write my own audio module for RR<->Foobar.
    I use this module now but it works via COMAutomationServer so it is not quite stable (((
    2 Mitch: unfortunately I am not good at writing a COM objects in C++. Is it possible to get your sources? I think I can add the supporting of .cue sheets and then you will be able to add this functionality to the RR after your review.
    Thank you in advance,
    Alex
    Odessa, Ukraine
  2. #82
    Sep 2012
    Germany - Munich
    exist the riderunner server component seperatly to install without installing complete riderunner?
  3. #83
    Mar 2011
    I recently formatted the PC and I put Windows 7 32bit. I do not know why RR with foobar does not work anymore. the volume remains in foobar fully lowered. what's up?
  4. #84
    MySQL Error
    Oct 2004
    delete foorr.ini
    that stores the default foo volume
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #85
    Mar 2011
    Quote Originally Posted by mitchjs View Post
    delete foorr.ini
    Hello Mitch. where do I find this file ini ??
    Edit..
    found. . Tomorrow I try car. . hopefully good
  6. #86
    Mar 2011
    nothing to do mitchjs. rr starts when the volume is 0.; (
  7. #87
    Mar 2011
    hello mitchjs I found the problem. The cause is if I enable the function in rrconfig, Page 2 "Fade-in Volume @ Startup And Hibernate Resume". If this option is not flag foobar works regularly.
  1. Replies: 161
    Last Post: 06-27-2011, 10:12 AM
  2. Visualisation for foobar
    By anuchit in forum RR Plugins
    Last Post: 06-09-2011, 12:40 AM
  3. foobar uis for touchscreens
    By mercus in forum Software & Software Development
    Last Post: 02-03-2008, 06:13 PM
  4. foobar 2000 w/ dsp or kxproject with ufx?
    By zyrus1 in forum General MP3Car Discussion
    Last Post: 10-29-2006, 10:06 PM
  5. Foobar?
    By greenman100 in forum PowerVoice
    Last Post: 12-19-2005, 08:41 PM
