c:/Users/<Me>/Documents/RideRunner/Skins/Carwings_Dynamic_Lite/menu.skin
IMHO that is a good candidate for FAQ
I just made a default installation of RR, and trying to develop a plugin.
RR shows "CARWINGS" in top left corner, it obviously uses CARWINGS skin;
However, search does not find and related *.skin or *.ini files, as described in the manual:
The code you make will basically be loaded through a simple skin definition that can be added to any existing skin as desired. The below loads the example extension plugin included in RR's sources:
X,MyExtension
Extenesion demo does not include any skin files whatsover.
I've attached complete list of files in my installation.
Thanks for all your help.
Will contract for C++/Win-Linux/PIC jobs
X, xxxx is deprciated, DONT USE
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Thanks @mitchjs, I already figured that. I managed to launch RRCam and investigating approach that @Enforcer has originally recommended,
L06,619,460,164,63,255,255,255,16,"Arial:B","EXEC; SENDMSG;RRCam.exe;BUTTON6||=",
seems to be quickest in terms of porting effort. I could actually continue maintaining the same code base.
ParkingAssistant runs in background. Is there any way it can make RR execute commands (like two-way SendMessage) ?
sure, did you write it? i dont know what it is.. do you have access to its code
you can just check if rr is running..create the SDK object, and tell RR to do stuff![]()
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Hmm, not sure if I understand >> did you write it?<< I meant supporting code base of that creature.
RRCam approach is such that is has exe file C:\Users\<username>\Documents\RideRunner\Skins\Carwings_Dynamic_Lite\Plugins\RRCam\RRCam\RRCam.e xe
which is controlled by Skin buttons trough SENDMSG. Looks like it calls winapi SendMessage.
Ideally, I would prefer to avoid linking against RR libraries and keep talking both ways using SendMessage. Not sure if that is possible though.
I'm actually thinking to run with command line parameter "parker.exe --roadrunner".
you CAN use sendmessage, its just not a PLUGIN (per say), so we dont want to use that term
keep in mine that rrcam, is really one way communication
just target riderunner window, and send command via string via WM_COPYDATA
need an example? in what vb6? .net?
direct SDK controll is much easier
SDK.Exec("mycommand")
if you want to have RR Skin elements, like indicators and lables, much easier to make a real plugin
---------- Post added at 12:54 PM ---------- Previous post was at 12:52 PM ----------
oh and you dont link against any RR libs
its an COM Object, so you just create the object, and use it, the OS handles the behind the scenes
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Thanks again @mitchjs; I tried following your recommendation (easier to use SDK method, easier access to skin, etc). And modified C# sample, exporting all the parking assistnant methods. Please see the attachement - it has C# prototype module.
1) What is not clear from example, provided by @guino, where is sample skin mentioned in
2) Is there any plugin example of actually drawing (painting) into the Plugin area on paintevent ?Code:public int ProcessCommand(string CMD, object frm) { int result = 0; switch (CMD.ToLower()) { case "boo": SDK.Execute("PlaySound;scary.wav"); break; case "yeah": SDK.ErrScrn("title", "subject", "error details"); break;
3) What commands can be used to Suspend multimedia playback and bring the plugin up by device event and than resume and hide Parking Asistance plugin?
I suspect that I wont be able to accomplish all those tasks without help from RR authors, so thanks for your help guys.
you dont paint! rr paints!
RR manages all the skin drawing...
you just do reaction to buttons, fill in labels, update indicators...
you can send the pause commnd
SDK.Execute("pause");
that will pause the playing music/radio/xm/sirius
and "resume" resume it
u want to bring up your app in a skin...
make a skin file with an embedded window definition for ur window
and
SDK.Execute("load;skinname.skin;;myexe.exe;mywindo wname")
something like that
can always try commands in SKINTOOL 1st
baby steps
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Thanks Mitch, will try that out.
