Results 1 to 9 of 9
Thread: Satellite Radio and RR Config
    Constant Bitrate besjr69's Avatar
    Feb 2011
    ALL,
    I've searched and searched and can't seem to find the answer to my question in the forum. I apologize if I've overlooked this as it seems it would be a common questions. I've been trying to configure RR to play my satellite radio. I have the MJS SC-C1 with SC-C1 universal receiver. RR recognizes the SCC1 and outputs the channels on the screen. However, I do not hear any audio. Below is my audio setup:
    - Zotac IONITX F-E MB
    - Using onboard sound in 5.1 config
    - Using external USB for line in (I require 5.1 for audio so needed for additional line-in input)
    - RR config'd to use Winamp Line In plugin
    I have RR config'd to use the line-in plugin. I assume this is much like CF where using the recording interface allows the system to output the 2ch line in as a 5.1 and also have EQ controls. I have it set to record the 'USB Line' input.
    What am I doing wrong? Or could someone please send me their config for a multiple soundcard setup where the line in is on a separate soundcard than their output.
    Bobby
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Dyou have the line in plug in working for winamp outside of RideRunner?
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
    MySQL Error
    Oct 2004
    yes.. you have to preconfigure (or determine the line in info... also... make sure its not muted, the record in)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Feb 2011
    I finally got the plugin to work using the Sirius Demo. I went back in RR and it was working as well. Don't know what happened. Now I have the same issue in RR as with CF. Whenever I resume from hibernation, there is no sat radio audio. I checked the line input to see if it was muted and it is not. I think there is a sequence option where the USB sound card is being enabled after RR or CF starts. Once I exit and restart the audio plays. Quite annoying, but I guess I'll have to deal with it until I can figure that out.
    Bobby
    MySQL Error
    Oct 2004
    are you sure its just an audio issue? a lot of people wire the tuner power wrong
    it must be on when the pc is on, so the red wire connected to ignition/accessory is NOT A GOOD CHOICE
    in RR, there is resume delay options....
    and there is no plugin in RR, its just part off RR....
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2011
    Mitch,
    I have the tuner is wired to 12vdc constant power. And I misspoke about a the plugin. I will play with the resume delay settings to see if that fixes it. Thanks.
    MySQL Error
    Oct 2004
    ok, there is also a USB Audio option (forget what it technically does)
    usbsound=true
    in rr.ini
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2011
    Mitch,
    I was able to get it working by disabling the USB Sound option and setting resume delay to 5. Thanks for all the help.
    Bobby
    MySQL Error
    Oct 2004
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Replies: 3
    Last Post: 10-22-2008, 12:11 AM
  2. Satellite Radio
    By slammedsl1 in forum Newbie
    Last Post: 11-19-2007, 03:30 PM
  3. Cinergy radio config in RR Config ?
    By pike in forum Road Runner
    Last Post: 06-11-2006, 07:16 AM
  4. Replies: 7
    Last Post: 02-09-2006, 08:42 AM
  5. how to set tv & radio in rr config?
    By dabper in forum Road Runner
    Last Post: 01-20-2006, 11:43 AM
