johnnySierra sources are completely redone in 6/1!
there are many changes to sources...
i did a test on my pc.... with the newest (which is 6/6 internal) and when my pc resumed
right at radio screen, my radio station list was there
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Tested also with carwings: same problem!
My radio is a Silabs, with line-in plugin and Winamp.
In RR.ini resumemusic=0.
Mitch, I have feeling that this was discussed before in the past, sooo...here it goes..The RR Version on the splash loader screen don't match up to the RR version that's shown in the RRConfig. This is still OK then right? Just wondering...
i dont know what rrconfig does...
that info to me is meaning less...
i wouldnt recomend using it, when you're an experienced RR user
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
well.. that is then resumemusic=0, technically when it resumes radio isnt active
no source is...
and technically you shouldnt be at that screen, you found a hole in the concept
me i would not even have the option of resumemusic=0
set it to 1... and move on... i would have to make a core decision what to do
if you resume, with resumemusic=0
my 1st thought is to put you at MENU.skin
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
I got an error with the video skin (not DVD). There's a pop up error from Media Player Classic with the following error:
Unrecognized switch(es) found in the command string:
C:\Program Files\RideRunner\mplayerc.exe /fullscreen /slave 1312708
These are the video related settings in my RR.INI
[Video Player Setup]
videoplayer=MPCVidRR
mpcpath=C:\Program Files\RideRunner\mplayerc.exe
Is Media Player Classic no longer supported for Video files playback?
It's normal , i had the same issue and i have modifier with RRconfig the dvd player path:
DO NOT DO THIS, if your player is media player classic!mpcpath=C:\Program Files\Media Player Classic - Home Cinema\mpc-hc.exe
(NON HOME CINEMA version that is)
Hi Mitch
I used to do this in RR.ini
visuname=!ShpeckEmbedWndClass!Classic Spectrum Analyzer
and everything was OK.
If I want to use it, should I change the command to
RRFooVisuShpeck=!ShpeckEmbedWndClass!Classic Spectrum Analyzer
I tried it in the 2011-06-01 RR, and the visualization does not come out until I press "Shift+Alt+V"
The command of my audio_player.skin is "LOAD;audio_player.skin||VISU"
Kindly help, thank you very much in advance!
br,
/Vinchan
If you use these values, all must to be ok
visuName=!ShpeckEmbedWndClass!
RRFooVisuShpeck=AVS
You don't need to create a cmd into foobar2000, just use the VISU command as you use it with winamp !
