Results 1 to 8 of 8
Thread: Max Speed Attenuation Question
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    Question Max Speed Attenuation Question
    I was wondering if there was a way to get the GPS-controlled Volume to max out at a certain percentage (below 100%) and stay there once it hits the max speed.
    I have it set up right now as:
    Min Speed: 0 --> Volume: 30%
    Max Speed: 70 --> Volume: 70%
    The problem is that the Max volume seems to just scale with my speed, even past 70mph. If I'm going 85mph, the Volume will go up to ~80%.
    The road noise in my car doesn't really increase that much between 60 and 80mph, so I'd like to be able to have the volume stay at 70% once I get up there. Is there a way to get RR to do this?
    Thanks!
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    May be, you can use this RR command with the label GPSSPDN:
    Code:
    "IFVAR"		- simple variable compare (equals or not equals only and string contains)
    						ex. "IFVAR;myvar=5;DOTRUE<<DOFALSE"
    						if myvar = 5 then "DOTRUE" would execute, else "DOFALSE"
    						ex. "IFVAR;myvar<>1;DOTRUE<<DOFALSE"
    						if myvar <> 1 then "DOTRUE" would execute, else "DOFALSE"
    						ex. "IFVAR;MYVAR~#;TRUECODE<<FALSECODE"
    						if MYVAR contains a "#" then "TRUECODE" else "FALSECODE"
    IFVAR;GPSSPD=0;SETVOL;Player;30<<SETVOL;Player;70
    But the RRextended plugin can certainly make a better setup.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That IS the way it is supposed to work. Which of the modes did you set it to? I personally use the linear, but I also have mine setup in a non std way to get it work how I want it to work and works as such.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Bay Area, CA
    I have it set to Linear, controlling the main volume line.
    I'll recheck it when I get home, but in the 3+ years I've been using RR, it has always gone past the Max volume for me.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I checked this on the way home today and did find that it just blows right past the max. I could check the code and see why it goes over...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    MySQL Error
    Oct 2004
    some settings in RRconfig arnt 100% right for this... that might be related...
    these are the known settings...
    [Native GPS - Speed Controlled Volume]
    SpeedAtt=False
    SpeedAttMute=True
    SpeedAttMaxStep=100
    SpeedAttMode=line
    SpeedAttVolZero=70
    SpeedAttSpeedA=0
    SpeedAttSpeedB=70
    SpeedAttVolA=50
    SpeedAttVolB=100
    SpeedAttGainAt50mph=5
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Bay Area, CA
    Here's what my rr.ini says under the GPS Volume settings:
    speedatt=true
    speedattmute=true
    speedattunit=mph
    speedattmode=line
    speedattvola=30
    speedattvolb=75
    speedattspeeda=0
    speedattspeedb=75
    speedattmaxstep=10
    I don't see "SpeedAttVolZero" or "SpeedAttGainAt50mph" anywhere. Could that be the problem?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, I fixed this & just have to sumit the change, will be in next months update.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Release: Navigon Voice Guidance Attenuation
    By swift_gti in forum Road Runner
    Last Post: 07-18-2009, 05:34 AM
  2. Attenuation
    By Otterski in forum Car Audio
    Last Post: 05-15-2008, 09:30 PM
  3. Variable Speed Case Fan / Motherboard Question
    By tbird2340 in forum General Hardware Discussion
    Last Post: 10-10-2007, 10:25 AM
  4. NavController Speed question
    By vizfxca in forum DigitalMods (Scripts / API)
    Last Post: 02-17-2007, 08:09 PM
  5. Attenuation
    By tibby01 in forum Centrafuse
    Last Post: 12-31-2006, 04:40 PM
