Results 1 to 5 of 5
Thread: transisions not working?
    Sep 2007
    Export, PA
    So i was testing out the different transisions and it appears that some of them just dont work... 15 (shift left) and 16 (shift right) do the exact same thing...
    wondering if anyone else has noticed this?
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
    MySQL Error
    Oct 2004
    i tested 15 and 16, they work as expected, one to the left, one to the right....
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Sep 2007
    Export, PA
    odd... i was using the 6/1 version, tried using them as commands, skin parameters, in skin tool, etc.....
    MySQL Error
    Oct 2004
    6/1 is fine... commands?
    you can use them in skins as;
    /EFFECT=16
    OR
    /EFFECTIN=15
    /EFFECTOUT=16
    or in rr.ini
    transition=
    or
    transitionin=
    transitionout=
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2007
    Export, PA
    "EFFECT" - This allows you to dynamically select the effect used when trasitioning FROM the current screen to another.
    Example: "EFFECT;0" (fade) -- check /EFFECT skin parameter above for range of values.
    i tried using /EFFECTIN and /EFFECTOUT in the skin file and it didnt make a difference...
  1. ubs cable working outside not working in car
    By 00christian00 in forum Newbie
    Last Post: 07-25-2005, 12:47 PM
  2. DVD not working
    By DK888 in forum General Hardware Discussion
    Last Post: 05-01-2005, 11:06 AM
  3. TS working... not working... work... not...
    By bulgogi777 in forum General Hardware Discussion
    Last Post: 01-11-2005, 10:25 AM
  4. Want To Buy Working Lcd
    By outofmyway6 in forum Classified Archive
    Last Post: 09-17-2003, 02:54 PM
  5. DC DC PSu not working
    By phil.45 in forum Power Supplies
    Last Post: 05-20-2002, 03:26 AM
