Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Upcoming RR 7-1-2011 Release
    MySQL Error
    Oct 2004
    I just want to point out a few small things...
    #1 if you use MPC-Home Cinema for DVD or video... a new settings must be set
    (if the player exe is outside of rr path)
    example:
    MPCHCPath=C:\Program Files (x86)\RideRunner\mpc-hc.exe
    min version of v1.5.2.3225 is needed for correct DVD Control
    #2 bunch of new DVD settings, for better DVD handling + ISO mounting...
    [DVD Player]
    DVDPlayer=MPCHCVidRR
    RRDVDDrive=D
    RRDVDFoldersPath=E:\_RideRunnerTestMedia\DVD\
    RRDVDBrowse=False
    RRDVDISODrive=Z
    RRDVDISO=C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe
    RRDVDISOMountCmd=
    RRDVDISOUnmountCmd=/u
    #3 two settings for radio have changed, UseLineInPlugin & LineInPar (added "radio")
    example:
    RadioUseLineInPlugin=False
    RadioLineInPar=line://dev=0,title=Radio
    #4 removed Phidget support from core RR, I have created a plugin (need someone who has phidgets to test)
    A bunch of other things... for sure kept busy in JUNE, ill post the history shortly
    thanks
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Can I put in a small request for MPC-HC?
    A switch/ini setting to allow MPC-HC to control the resume.
    ie RR just loads MPC and sends the play command, let MPC remember where it last was.
    Cheers E.
    MySQL Error
    Oct 2004
    for dvd? for video?
    i have done alot of work on dvd resume... and i mean a lot
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Video.
    I haven't tried the DVD side yet, but I'm still having issues with the resume feature on videos, these are Mpeg2 videos that have been ripped from DVD's.
    If I use MPC without the ini file being altered by RR I can get the video to continue to play from where it left off. (Have to press play in MPC though).
    But once RR has changed the ini then I have to reload the file and then it will only play from the start. (NB this is all outside of RR)
    In RR it will play the video fine but will always start from the beginning.
    MySQL Error
    Oct 2004
    hmm.. for video resume, all rr does is tell mpc to seek to time xxx after its playing
    simple, i have never seen it fail...
    if you want pop a mpeg2 video on my ftp
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Not sure it will get there in time. Reckons on 10 hours and I only have 2 1/2 hours left at work (can't access your ftp at home for some reason) and I'm not back till Tuesday hmmmm?
    MySQL Error
    Oct 2004
    i got the sample
    works fine, resumes right where i left it, when i exited video player
    some infomation:
    MPC-HC V1.5.2.3268
    using ALL internal Filters
    no external (none needed)
    and these settings... important...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Nope.
    I have those settings, still goes back to the beginning every time.
    Running on XP Pro
    mpc version is V1.5.2.3268
    RideRunner is 23/06/11
    Carwings skin
    Debug doesn't seem to tell me much regarding video.
    Any files I can send you to help?
    MySQL Error
    Oct 2004
    when you exit video... take a look at video.ini
    while sitting at the main menu
    the top line is the video time that it will resume to
    example:
    01:10
    -2
    1
    see if that looks valid...
    you do have the options in mpc-hc remember last position unchecked, i have seen that be checked and grey.. make sure its unchecked
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    video ini has
    00:00:20
    0
    1
    Both remember positions are unchecked and greyed out.
    Just tried with the same video.ini settings as you have, but it made no difference.
  1. RR 06-01-2011 Release - its already too HOT
    By mitchjs in forum Road Runner
    Last Post: 06-26-2011, 01:30 PM
  2. RR 04-01-2011 Release
    Last Post: 05-18-2011, 11:19 PM
  3. Replies: 15
    Last Post: 05-17-2011, 11:33 AM
  4. Replies: 21
    Last Post: 04-01-2011, 09:59 AM
  5. RR 02-01-2011 Release
    Last Post: 02-22-2011, 05:46 PM
