Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 77
Thread: RR 07-01-2011 Release
  1. #11
    MySQL Error
    Oct 2004
    Quote Originally Posted by RS200Z View Post
    I have been using line in plugin for my Silabs radio for a long time now. With this new version, I need to changed the settings names to RadioUseLineInPlugin & RadioLineInPar respectively otherwise radio doesn't work as mentioned.
    However, there is a problem, if I mute Winamp, I am still hearing radio played over the Wave output.
    In fact, I am hearing echo now as I believe the radio output is now sent to the wave and winamp output simultaneously with some slight time difference of course which explains the echo...
    oh crap, good catch, i forgot in the plugin, to update that to disable audio capture!!!
    a little brain power says... put in rr.ini (along with the other settings)
    uselineinplugin=true
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    MySQL Error
    Oct 2004
    if you guys want to write your own RRCONFIG, feel free.. the work that Bluezx3 put into the existing one, is amazing...
    and the work we are NOW putting into the new RRCONFIG(while it still looks the sameish) is hours upon hours
    and NO one here gets paid to do this, all this stuff is done when we have "FREE" time
    so my advise is show some patience
    and edit the rr.ini with a TEXT editor
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  3. #13
    MySQL Error
    Oct 2004
    Quote Originally Posted by Sonicxtacy02 View Post
    how nice would it be to create a config plugin so you can actually change the settings inside RR, a la another well known front end.
    just too many settings
    and they are SELLING a product, we arnt selling anything here, all the work we do is in our freee time
    and some of us already spend many hours on it...
    the GUI/code work would take a very long time to do the plugin
    not to mention, they have very little number of settings, i bet, under 25 options...
    we have way more
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #14
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mitchjs View Post
    and edit the rr.ini with the TEXT editor
    That'll be notepad then, FTW.
  5. #15
    Oct 2010
    Ivry-Sur-Seine (France)
    The variable LISTPOS = Code LISTPOS-1 why? it's desired?
    thanks
  6. #16
    MySQL Error
    Oct 2004
    Quote Originally Posted by shaken94 View Post
    thanks
    hu?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #17
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I think he means why do you have to subtract one to get the correct value/item.
    It's because the lists are stored in arrays starting from '0'
    At least that's what I think he's on about.
  8. #18
    MySQL Error
    Oct 2004
    ok, yea...
    0 is valid
    position 0 is 1st item in list
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #19
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Its easy for us "programmers" to better understand, but for a std user, lists typically start at 1. Pro's and Con's...
    Lists are either Zero based or One based, depending on the program coding, here its coded as a Zero based list.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  10. #20
    Oct 2010
    yes I understood the 0 or 1, I am developer but why a difference between the variable and the code. Now if it's for standard users I can understand.
    thanks
  1. Upcoming RR 7-1-2011 Release
    By mitchjs in forum Road Runner
    Last Post: 07-15-2011, 10:11 AM
  2. RR 06-01-2011 Release - its already too HOT
    Last Post: 06-26-2011, 12:30 PM
  3. RR 04-01-2011 Release
    Last Post: 05-18-2011, 10:19 PM
  4. Replies: 21
    Last Post: 04-01-2011, 08:59 AM
  5. RR 02-01-2011 Release
    Last Post: 02-22-2011, 04:46 PM
