Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 77
Thread: RR 07-01-2011 Release
  1. #41
    MySQL Error
    Oct 2004
    Quote Originally Posted by TMF View Post
    I have been coding for a living for 30+ years. Maybe someday I will switch to C#. For now, I'm happy with Delphi and the results. Regardless of the language, the underlying data structures are more important. In my humble opinion of course.
    Actually, I tend to agree with this. I, for one, do not want to haul around a keyboard and mouse in the car to make changes to the system. Once I get the PC programmed the way I like and settle on the skin I will use, I will most likely never change it or need rrconfig again. However, if I am on the road and feel I do need to make a change, say to the speed volume settings or the day/night gamma, I will want something that I can use easily with just a couple presses of my finger on the screen.
    These are the types of options that should be part of RR, either directly or via a skin for configuring the system. It has been eluded to that the rr.ini can be mostly embedded in a skin. If this is the case, then all of it should be done this way to make it easy to use.
    But if there is to be a standalone rrconfig and it is being done in C#, then the designer needs to read the UXGuide and follow the recommended specification while laying out the controls in visual studio. Again, this goes to the mantra, "if it's worth doing, it's worth doing right."
    John
    like i said, if you want to do it in a skin, create it... make a small plugin to manage some special commands you create to aid in updating the data and displaying it...
    and do the skin, keep in mind, to do it all, there prob is 100+ settings
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #42
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mitchjs View Post
    nope, you are wrong... LISTPOS the var is VERY NEW, only got introduced in 3/1 release, and prob not many people(plugin developers) ever used it, they still use the OLD label version
    also, other LABEL based commands are 1 bades, like CLDEL;1 would delete the 1st item in the list...
    OK, if it's a new thing, then I bow to your decision.
  3. #43
    MySQL Error
    Oct 2004
    believe me i didnt want to change it so fast, but blueZX3 and i talked it over, and it should be synced, and since the rest of the list stuff was 1 based, it became easy decision
    (its on ftp)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #44
    Oct 2010
    Ivry-Sur-Seine (France)
    Cool for the variable LISTPOS, and thanks to bluezx3 and mitchjs.
    It seems to me it is natural to be sync.
  5. #45
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    question and probably a small request.
    is there a label or var, that i can use to get video path?, i need what "trackpath" does for audio, but for video.
  6. #46
    Jul 2010
    Hi, so i never managed to sort out how to get radio muted when i go to music/videos.
    I installed winamp and am using the 'Ultimate radio' module.
    what settings do i use to:
    1. Get the radio working
    2. have the radio muted when going to music or video, then unmuted when going back to radio etc?
    I currently have 'listen to this device' ticked in windows mixer as otherwise i don't get anything from the radio. Is this correct?
    Thanks for any help.
    Also with this new version will anything change for this?
  7. #47
    MySQL Error
    Oct 2004
    Quote Originally Posted by Sledge1 View Post
    NO, dont use listen to this device
    that is NOT ment for anything other than diagnostic purposes
    you need to set up RR to use the right line mute/unmute
    since every system(well not really) is different...
    and since ur win7 you need proper audio drivers installed
    detemine what line you are connected to.. like rear green... or what
    and get its number from debug.txt
    and put that in rr.ini
    example
    RadioLine=1
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #48
    MySQL Error
    Oct 2004
    Quote Originally Posted by EL CAMINO View Post
    trackpath is a overly complicated label...
    not sure when you need the path to your file
    LISTPATH var has the path to the list
    with you can build a path...
    this is of course at LIST selection time...
    so... what do you need this for?
    Added basic trackpath support when active source is VIDEO (the current PLAYING video)
    (on ftp)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #49
    EL CAMINO's Avatar
    Jul 2005
    (on ftp)
    on a PI, i need video path to update some labels. i have an Sql db that stores movies info, and i want to use video path to search for current videos info.
    thankyou for the addition...
  10. #50
    Jul 2010
    example
    RadioLine=1
    I'm probably going to switch soundcard anyway, but where do i find debug.txt ?
  1. Upcoming RR 7-1-2011 Release
    By mitchjs in forum Road Runner
    Last Post: 07-15-2011, 11:11 AM
  2. RR 06-01-2011 Release - its already too HOT
    Last Post: 06-26-2011, 01:30 PM
  3. RR 04-01-2011 Release
    Last Post: 05-18-2011, 11:19 PM
  4. Replies: 21
    Last Post: 04-01-2011, 09:59 AM
  5. RR 02-01-2011 Release
    Last Post: 02-22-2011, 05:46 PM
