Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 77
Thread: RR 07-01-2011 Release
  1. #61
    MySQL Error
    Oct 2004
    Quote Originally Posted by indydn View Post
    I too am having an issue getting the HDRadio to play if "listen to this device" is NOT checked. I have updated to the latest Realtek driver for my hardware. The radio input is connected to the Blue connection which is line 1. I have the following in my rr.ini:
    [Radio]
    radio=HDRadio
    allowallfreqs=false
    radioline=1
    uselineinplugin=true
    lineinpar=line://title=Radio,srate=44100,bps=16,nch=2
    uselineinsingleinstance=false
    userbds=false
    RadioPort=1
    HDRadioType=Auto
    From my debug.txt:
    Start Sequence: Starting Radio Device...
    HDRadio---> HDRadioPowerOn: MyHDRadio.Open
    Start Sequence: Starting Serial Devices...
    Start Sequence: Starting Mixer...
    VMC---> Set object successful
    VMC---> SOURCE: Mixer line #1: "Rear Blue In"
    Am I missing something?
    Thanks!
    you dont mention what your issue is.. BUT
    you should make your decision to use line-in plugin or not...
    ok.. assuming your using Winamp
    and you installed the line-in plugin... [ http://www.winamp.com/plugin/linein-plugin-v1-80/84040 ]
    and configured it
    then
    radioline=0
    would be correct
    not using the line in plugin
    radioline=1
    uselineinplugin=false
    would be correct
    my guess is you didint install line in plugin...and configure it (just by judging the llineinpar)
    NOW i should mention.... in 7/1 RR and onward
    •if you use the line in plugin for radio, please change to the new settings
    RadioUseLineInPlugin & RadioLineInPar
    just keep it simple 1st time
    RadioLine=1
    RadioUseLineInPlugin=false
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #62
    Aug 2008
    Indianapolis, IN
    Quote Originally Posted by mitchjs View Post
    and configured it
    then
    radioline=0
    would be correct
    radioline=1
    would be correct
    RadioLine=1
    Sorry Mitch, let me be more specific. I understood previous posts to indicate "Listen to this device" should not be selected in the Line In properties for the sound device. The only way I am able to hear the HDRadio is by having this option selected. It doesn't matter if RadioLine is set correctly or not. It doesn't matter if I'm using the line in plug in or not. Simply if it is not selected, I don't hear the HDRadio. No problems with Internet radio or Winamp audio. It makes sense to me that it should be enabled and disabled from within the software and that's how I understood the comment not to use this setting (it's for debug/testing use.)
    So far I haven't run into any issues with having it set. I'm just trying to make sure I have things setup correctly to avoid future issues. I'm new to RR and DFX. I'm working on one item at a time. The radio and iGuidance will be the primary things I use. I got iG working and want t make sure I have the HDRadio working correctly before moving on to more features.
    Thanks for your patience with noobs like me. It takes a while to digest all the information that currently resides in the forums. Keep up the good work. Thanks!
  3. #63
    MySQL Error
    Oct 2004
    if you connected audio to line in blue, which is #1
    all you need in rr.ini is
    RadioLine=1
    RadioUseLineInPlugin=False
    ASSUMING RideRunner V 7/1/2011 >, since you dont provide me with version of rr...
    AND this is assuming, the PLAYBACK device in on the SAME device as the line in...
    you really need to understand how audio works in windows
    and please test with carwings...keep it simple!!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #64
    Jul 2010
    Where is debug.txt?
    And how do you guys make all these changes with the PC in the car? I have to keep running inside to this PC, then run back outside and try to remember what i need to change, come back in, double check, go back out etc..
    I'm going to remove RR and install the new version and the linein plugin and see how it goes...
    Edit: Well that went better
    Seems to be working properly now.. although a tad quiet. (have turned up the linein level to 90, and reset the volume in the standalone app for the venice 7 module) but it just seems low..
    Will see how it is with the new PCI soundcard when i get that in..
  5. #65
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Sledge1 View Post
    Wireless and VNC
  6. #66
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Or RRUpd8 lol.lol.lol.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  7. #67
    Aug 2008
    Indianapolis, IN
    RadioLine=1
    I thought I understood how audio works in Windows... Let me start from ground zero and work forward.
    The system is a MSI Fuzzy GM965 motherboard with an integrated Realtek ALC888 7.1 channel audio device. I've got a clean instal of Windows 7 Home Premium, all the latest Windows updates and drivers. I have the front speakers (green), rear speakers (black), and the HDRadio line in (blue) connected and identified in the Realtek driver. The HDRadio is connected to COM1 (9pin serial connection). Using HDRadio PCR.exe I can controll the HDRadio. I am only able to hear the radio if I launch Control Panel / Sound and on the Recording tab under the properties of Line In I must select "Listen to this device" on the Listen tab. Without this being checked, I do not hear the radio audio.
    From here I can do an install of RR (7/11). Update rr.ini Radio section:
    [Radio]
    radio=HDRadio
    allowallfreqs=false
    radioline=1
    userbds=false
    RadioPort=1
    HDRadioType=Auto
    Running RR, I am only able to hear the Radio audio when "Listen to this device" is slected in the linein properties of the sound settings. Without it selcted, no radio audio. All other audio works fine regardless of this selection. (I get a beep when a button is pressed and I can hear MP3's regardless of the "Listen to this device" setting.)
    With previous posts indicating "Listen to this device" should not be selected, how does the radio audio work? It makes senes (to me) that since the line 1 is being identified as the radio input that RR should be activating this line in when the radio is selected and deactivating it when the radio is not being played. Do I understand this correctly?
    If that is how it should be working, then it appears that either RR is not selecting the line properly or the driver is not working correctly when RR does activte the line in. If this is workinf for others, I would tend to belive it is something related to my hardware or software setup.
    I can move the line in from the blue and connect to the pink. Update radioline=2 and get the same rsults.
    (rr.ini & debug.txt ttached)
    Attached Files Attached Files
  8. #68
    MySQL Error
    Oct 2004
    FORGET RR for a little bit!!
    use HDPCR... get something tuned
    go to audio->playblack devices->Levels->Rear Blue, and UNMUTE it and adjust its level, my guess you got it at 0
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #69
    Aug 2008
    Indianapolis, IN
    Crap... I hate staring at the obvious and not seeing it. The line was muted. I was fixated on the recording device properties and wasn’t looking at playback devices. Thanks Mitch!
  10. #70
    MySQL Error
    Oct 2004
    ok, well its muted, now back to RR, RR will unmute it when radio is selected, BUT you have to set the LEVEL
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Upcoming RR 7-1-2011 Release
    By mitchjs in forum Road Runner
    Last Post: 07-15-2011, 10:11 AM
  2. RR 06-01-2011 Release - its already too HOT
    Last Post: 06-26-2011, 12:30 PM
  3. RR 04-01-2011 Release
    Last Post: 05-18-2011, 10:19 PM
  4. Replies: 21
    Last Post: 04-01-2011, 08:59 AM
  5. RR 02-01-2011 Release
    Last Post: 02-22-2011, 04:46 PM
