Page 1 of 8 12345678 LastLast
Results 1 to 10 of 77
Thread: RR 07-01-2011 Release
    MySQL Error
    Oct 2004
    July already??!??! need i say more..
    Download HERE
    whew, a bunch of stuff...
    (well seems mostly more DVD/MPCHC tweaks)
    • if you use the line in plugin for radio, please change to the new settings
      RadioUseLineInPlugin & RadioLineInPar
    • if you use Media Player Classic - Home Cinema (and you all should be)
      MPCHCPATH= setting!!!
      (if you have mpc-hc.exe in the RR Root path, you dont need this setting)
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    6/29/2011
    - Removed Phidgets code from code, now in a plugin.
    * SpeedAtt Linear Mode, volume will not go above the speedattvolb setting
    6/26/2011
    * Tweaks to physical DVD playback with mpc-hc
    + Skin Label; "TRACKNAME" when physical dvd, it will use volume name
    6/25/2011
    + Skin Command; "DAYNIGHTSKIN" added back toggle support that was accidently removed on 10/1/2011 release
      Command will toggle between day and night skin, IF auto skin mode is disabled
    6/23/2011
    * Setting; "uselineinplugin" to "RadioUseLineInPlugin", due to vagueness
    * Setting; "lineinpar" to "RadioLineInPar", due to vagueness
    6/15/2011
    # If no File Types are specified for a DL, "*.*" is assumed.
    + Added CRLF command for entering Carriage Return on OSK (Plugin Support)
    6/14/2011
    * Media Player Classic - Home Cinema min version of v1.5.2.3225 is
      needed for correct DVD Control
    6/13/2011
    * VIDEO/DVD Player; MPC-HC - rewrite of dvd resume logic, should now work with titlesets
    6/12/2011
    ! Setting; "RRMusicBrowse=" is boolean(true/false. Set true if you want to start the browse at last location, DEFAULT = false (and if not present in rr.ini)
      The last browsed path is now stored in resume.ini (Cache file)
      ex.  rrmusicbrowse=true
    ! Setting; "RRVideoBrowse=" is boolean(true/false). Set true if you want to start the browse at last location, DEFAULT = false (and if not present in rr.ini)
      ex. rrvideobrowse=true
    + Setting; "RRDVDBrowse=" is boolean(true/false). Set true if you want to start the browse at last location, DEFAULT = false (and if not present in rr.ini)
      ex. RRDVDBrowse=true
    + User Variable(READ ONLY); "LISTPATH" just like "DLPATH" but contains the current directory list path.
      used like "DLPATH" but no need to setvarbycode.
      joins, "LISTTEXT", "LISTDESC" & "LISTPOS" variables
    6/11/2011
    + Settings; "MPCHCPATH=x" where x is the full path to MPC-HC.EXE
      ex. mpchcpath=C:\Program Files\RideRunner\mpc-hc.exe
    + Skin Indicator; "COVERART" added support for DVD Browsing
      ex. iso file, will be the name of the iso.jpg/png
    	  if folder, will be the name of the folder.jpg/png
    	  if DVD Folder, will be the 1st found .jpg/png
    	  if RRBROWSE file, will be skinpath "dvdicon.jpg/png"
    6/10/2011
    + Skin Indicator; "ALBUMART" added support for DVD (selected dvd)
      ex. if iso file, will be name of iso.jpg/png
    	  if dvd folder, will be any file in root of the selected folder
    	  if physical dvd, will be "dvdicon.png/jpg" from skin path
    + Blocked "ONFILECLICK" event when going into a folder (DLs)
    + Skin Commands; "SKIPTO" & "SKIPTODESC" (when unsed on DLs)
      added optional 2nd arguemnt to ignore folders.
      ex. "SKIPTO;c;true"
    	  "SKIPTODESC;f;true"
    	  "SKIPTO;d;1"
    6/7/2011
    + Skin Label; "TRACKNAME" added some more DVD support (folders and iso).
      Will show folder name or iso file mounted.
    * Installer tweaks, added registry keys: IsProfileMode & ProfilePath
    # Foobar2000 Control Server fix for getting playing track, vs track in focus
      V1.0.2 is the new version, and installer will now install it in user components path
    6/6/2011
    # Tweaks to MPC-HC Video Player
    + Skin Command; "MIXER" will now check for a audio player named file.
      ex. when player is Foobar2000, RR will look for "mixer_foobar2000.skin"
      If no audio player based skin is found, "mixer.skin" is loaded as usual.
    6/5/2011
    # DVD will resize correctly when controls are shown
    6/4/2011
    + Installer RegKey; "ProfilePath" registry value, this will point to the root RR data path
      ex. "C:\Users\mitchjs\Documents\RideRunner" in this case RR in profile mode
    + Installer RegKey; "IsProfileMode" dword 1 if in profile mode, 0 if in legacy
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Cool,
    Thanks for your job !
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    rrconfig seems not to update those..
    was rrconfig updated to support those or do we have to do it manually in rr.ini?
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question
    Mitch, I just tried to install the newest, improved, lemony fresh RR on my test PC,..........but the date does not match up with present date, as you can see. So I stopped the install. Is this the right RR update posted on NISU?
    Thanx Bud.
    EDIT: I just went back on NISU and re-downloaded with same results.
    MySQL Error
    Oct 2004
    it prob is,just install it... i prob forgot to change that in the installer...
    when you run, it will tell u what version! (if you got a loaderscreen)
    geeze, it would have been smarter to do the complete install... and post the facts for the rest of the people
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    rrconfig as it is now, is obsolete
    we are working on a new one...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    how nice would it be to create a config plugin so you can actually change the settings inside RR, a la another well known front end.
    Live mp3Car Facebook Chat
    May 2005
    I have been using line in plugin for my Silabs radio for a long time now. With this new version, I need to changed the settings names to RadioUseLineInPlugin & RadioLineInPar respectively otherwise radio doesn't work as mentioned.
    However, there is a problem, if I mute Winamp, I am still hearing radio played over the Wave output.
    In fact, I am hearing echo now as I believe the radio output is now sent to the wave and winamp output simultaneously with some slight time difference of course which explains the echo...
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mitchjs View Post
    Then may I suggest you remove the last page of the installer which asks if you want to open up RRConfig.
    Quote Originally Posted by Sonicxtacy02 View Post
    I have thought about this many times. However because of the way RR keeps evolving it would be a never ending task, plus it would need access to the inner sanctum.
    May 2007
    Quote Originally Posted by Enforcer View Post
    "geeze, it would have been smarter to do"....
  1. Upcoming RR 7-1-2011 Release
    By mitchjs in forum Road Runner
    Last Post: 07-15-2011, 11:11 AM
  2. RR 06-01-2011 Release - its already too HOT
    Last Post: 06-26-2011, 01:30 PM
  3. RR 04-01-2011 Release
    Last Post: 05-18-2011, 11:19 PM
  4. Replies: 21
    Last Post: 04-01-2011, 09:59 AM
  5. RR 02-01-2011 Release
    Last Post: 02-22-2011, 05:46 PM
