Results 1 to 10 of 12
Thread: CPU temperatures in RR
    Feb 2006
    Hi
    Is it possible to add coretemp in the riderunner?
    In that case we can monitor the system while in RR, especially in this hot summer.
    Thanks!
    http://www.alcpu.com/CoreTemp/developers.html
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by vinchan View Post
    Hi
    Thanks!
    There is already speedfan and MBM5 in RR.
    Although I suppose a third can't do any harm.
    Feb 2006
    Quote Originally Posted by Enforcer View Post
    Hi Enforcer
    Does this mean that all I have to do are:
    1. Install RR
    2. Install Speedfan
    3. Find a skin that supports speedfan, for example, speedfan.skin
    4. Embedded the Speedfan.skin in to the skin I use, for example, elite lite 1.6.6
    Am I correct?
    br,
    /Vinchan
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    1. Yes
    2. Yes
    3. Sort of, you only need to have a skin that supports speedfan (like the iDrive skins /Blatant plug) or you can just add the labels to existing skins, have a read of skincommands.txt in the documents folder for all the labels available.
    4. No need to embed anything, add your own .skin file if you want to an existing skin
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Hi Enforcer
    1. Install RR
    2. Install Speedfan
    Am I correct?
    br,
    /Vinchan
    A very quick speedfan screen example based from the dfx4 screen !
    Attached Files Attached Files
    Feb 2006
    Quote Originally Posted by pierrotm777 View Post
    Hi pierrotm777
    Thank you so much, I will try it out right away.
    Feb 2006
    [QUOTE=vinchan;1449904]
    Hi pierrotm777,
    After trying out the skin, there must be something wrong with my settings.
    Could you kindly tell me what should I do with settings? Thanks in advance!
    My configuration is Windows 7 32bit SP1, RR 06-01-2011.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have moved these posts to a thread of it's own as they are not really related to the lastest release of RideRunner.
    Feb 2006
    Hi All,
    Thanks to the "deus ex machina", he has provided a convenient tool for people who uses Speedfan.
    The file is named showSFdata.exe which helps you to find out the sensor numbers detected by Speedfan.
    For instance SFVXX SFTXX and SFSFFXX.
    You can find the tool at http://www.mp3car.com/vbulletin/atta...showsfdata.zip
    The post is http://www.mp3car.com/road-runner/73...-speedfan.html
    Thanks to deus ex machina
    Jun 2007
    I use MBM5
  1. Extreme Temperatures
    By gremmie in forum Environmental Considerations in Mobile Computing
    Last Post: 01-05-2010, 08:58 PM
  2. Getting Wifi working in -40C temperatures
    By nobb in forum Wireless Communications
    Last Post: 10-02-2007, 01:50 PM
  3. Temperatures?
    By Jirka Jirout in forum MacCar
    Last Post: 06-10-2007, 01:58 PM
  4. summer temperatures.
    By inline4 in forum General Hardware Discussion
    Last Post: 05-22-2003, 04:47 PM
  5. Temperatures
    By tyger in forum General Hardware Discussion
    Last Post: 09-06-1999, 08:18 PM
