Results 11 to 20 of 30
Thread: Various RR and DFX errors rendering RR useless. - RESOLVED
  1. #11
    MySQL Error
    Oct 2004
    1st please attach rr.ini as say a .txt file or .zipped
    2nd, install proper video drivers, your directx is failing
    isnt there a dfx5.1 full installer? vs messing with 5.03 and a patch? im sure there is...
    and this is why it does nothing...
    7/13/2011 2:59:50 AM: Que Exec: True, audio_player.skin, "BrowserButton1", False
    7/13/2011 2:59:50 AM: Executing: BrowserButton1
    7/13/2011 2:59:50 AM: Command not executed: BrowserButton1
    (sound like an exectbl.ini issue)
    start simple... use carwings...make sure music via normal rr native browser is working..
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    MySQL Error
    Oct 2004
    https://autoappmart.com/products/DFX...RideRunner_162
    its a little hard to find in appstore, cause the screen shot is used as icon, vs df5 logo
    now i know even with this, there are still many updates needed
    maybe in the thread, its really hard to tell..
    hope fully the update mech is going soon
    or i wish they would update this installer!!!!
    or post a new installer
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  3. #13
    Aug 2006
    Yeah I had already tried it once before in carwings and the player seemed to work (I was able to at least see the music folder and such). The reason I mentioned before that I had used the 5.0.3 + patch is because beforehand I had been using the "full" installer, just to eliminate the possibility of that.
    DX is up-to-date (it would show up in WU if it wasn't) and the drivers I will check later after work as well as posting the rr.ini file.
    Thanks for your response
    2006 Mazda 3 S Series
    2.3L 4cyl Engine
    Current Build
    - Commell LV-677 Motherboard
    - Intel Core 2 Duo T5500 CPU
    - Dual 512MB PC5300\667MHz RAM
    - Seagate 80GB SATA HDD
    - M2-ATX 160W PSU
    - Dynamix 8" LCD Touchscreen
    - VoomPC I Mini-ITX Case (Black)
  4. #14
    MySQL Error
    Oct 2004
    i didnt say update DX
    i said install video drivers, i can see from log...unless your doing remote desktop... that DirectX is failing!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #15
    Aug 2006
    Yes I was using Radmin to remote control the carpc.
    I was just addressing both mentions, the drivers and DX.
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
  6. #16
    MySQL Error
    Oct 2004
    ok, that explains...
    back to... the subject at hand
    the command processes though exectbl.ini
    "BrowserButton1","BYVAR;BROWSINGMODE;BROWSEMODE0<< BROWSEMODE1"
    thats line to be exact
    so.. in dfx5 folder... u should have exectbl.ini file, with that line in it
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #17
    Aug 2006
    Ok thanks, I'll check that file when I get home tonight as the CarPC is on my floor in my room right now. I'll also get a copy of the rr.ini file...
    Last edited by iNcArCeRaTiOn; 07-13-2011 at 02:48 PM. Reason: misread previous post
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
  8. #18
    Aug 2006
    I'd like to also mention though, that all functionality (even doing something as clicking the "Global Settings" button in the "Settings" menu) has never worked right. I could name several other things that has never worked and I'm not sure if it's because I need to install other various plugins or what. I've just never addressed them because the main core reasons I use RR and DFX (and have been for quite some time) has worked for the most part.
    Do you think whatever is affecting this is also effecting the other things that aren't working (little things like pressing a button and nothing happening or using things such as the stopwatch or lotto and just having LARGE bits of code where numbers should be like the lotto numbers?)
    If requested I could go through the whole thing and name the various issues that occur, probably would be best after the music is working again but I'd be willing to do so, or even install a screen capturing program and record it as a video.
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
  9. #19
    Aug 2006
    Here are the 2 files mentioned. Upon looking for exectbl.ini I also found another one that was next to it with a suffix (original) attached. I'm not sure what that is or what created it, but I included that as well.
    My question is why are these having issues (mainly the rr.ini file) or of question when it's a fresh installation of RR and DFX 5.1?
    Thanks for all your help!
    Attached Files Attached Files
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
  10. #20
    MySQL Error
    Oct 2004
    1st off no one else is having this issue...
    so its something special about your install
    since im not looking at it, i cant assume its really a good install
    but...we can do a teamviewer session !!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. RRMedia
    By ssteger in forum VaultWiki
    Last Post: 10-19-2009, 05:54 PM
  2. RRmedia db help
    By vtcom in forum Road Runner
    Last Post: 02-02-2009, 08:53 AM
  3. VS2005 + image rendering optimization...
    By Aldaris in forum Coders Corner
    Last Post: 02-03-2006, 08:14 AM
  4. Video rendering
    By ppgt94 in forum Software & Software Development
    Last Post: 06-01-2001, 03:26 PM
