Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Byind & exists???
  1. #11
    MySQL Error
    Oct 2004
    i dont know anything about that loadlist command....
    i cant see it doing what u think someone said it would do...
    "LOADLIST" - This allows you to load a playlist from disk, with a custom name. You specify the full path and optionally
    the name of the playlist. This commands only adds to the current playlist in repeat mode (i.e. "!LOADLIST").
    Example: "LOADLIST;C:\Test.m3u;My Playlist"
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    Jun 2011
    Thanks again. That's what I figured as well. What is the best way to load a cd into a playlist?
    I found a program called CLAmp (to control winamp) and this command works if I use it in windows "run" prompt.
    "C:\CLAmp\CLAmp.exe" /CDPLAY
    However if I use it in RR like RUN;"C:\CLAmp\CLAmp.exe" /CDPLAY it does not work. Also tried it with RUNW, RUNQW, AND RUNQ. None of the commands work. I think that ride runner is ending the process before it completes. In fact other RUN commands do not work either. Such as "RUNQW;cscript.exe" "$rrpath$\SmartPlayLists\queryWinamp.vbs" "$winamppath$" "type=0" " as in the SmartPlayListsRRPlugin. Any idea how to get the RUN command to work properly?
  1. Byind question
    By pierrotm777 in forum RR Skins
    Last Post: 01-10-2011, 02:32 AM
  2. Android frontend exists?
    By upspace in forum Other Cool Front Ends
    Last Post: 04-15-2010, 12:53 PM
  3. Byind & exists
    By Valheru in forum Road Runner
    Last Post: 04-08-2010, 02:40 PM
  4. Does anyone know if something like this exists?
    By AYahoo in forum General Hardware Discussion
    Last Post: 02-05-2005, 08:52 PM
  5. Why MediaEngine exists...
    By CarComp in forum ME Archive
    Last Post: 06-02-2003, 08:39 AM
