Results 1 to 10 of 14
Thread: is it me or rr?
    Jan 2008
    is it me or rr?
    when i first setup my carpc 3 years ago, everything worked perfect-- i am thinking it was a miracle.
    but since then every time i reinstall rr to get the latest version, i loose features.
    i have been staring at my carpc screen for nearly 4 hours now, searching tons of threads with no helpful results, and a system that is in worse condition then it was before when the nag screen was bothering me..
    i guess i just need someone to hold my hand and show me exactly what i am doing wrong that i can so consistently screw rr up..
    all i need out of rr is to: play music(mostly just select playlists), custom background, and black buttons with white text. as long as i have these three things, i'm good.
    i can't get my music to show up, and the color change is not working. but i can change the backgrounds!!
    programs:
    fresh download/install of the latest version of rr--july 2011 version
    fresh download/install of dfx 5.1+ donation patch
    before installing the new versions, i uninstalled the older versions of both, cleaned the registry, manually deleted the riderunner folder form my program files, and rebooted.
    after rebooting after everything installed, i configured rr to what i believe is identical settings to what it had before the update.
    now, many buttons will not work:
    • rescan database--i can get to the screen to rescan the database, the button will highlight, but nothing else happens.
    • color changer-- if i go directly to 'settings' and then 'color changer', the button will not work. if i change the background, and go back to the 'settings' window, i can access the color changer menu, but cannot select any color but black.
      also, once i access the color changer screen, the sample image on top freezes and stays there after rr is shut down.
    attached is my rr debug and ini files
    thanks.
    Attached Files Attached Files
    Nov 2004
    St Louis
    Welcome to my world!
    Hey Mitch! Get over here!
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    One huge issue I see is that I don't think RR has loaded the skin's exectbl.ini file. No where in that debug log, do I see a "EXECTBL Translation:" line, for which just loading the skin you should see several
    Example, 2 lines from my debug log:
    7/25/2011 9:12:16 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
    7/25/2011 9:12:16 PM: EXECTBL Translation: ONSKINSTART -> DFXDLLCHECK||PreloadCheck||ONSCREENCHANGE||ReLock| |SpeedIndicatorLoader||GreetingPlay||GreetingPopUp ||SAVENSETTOSKIN;SKINRELOADING;0||FBCONNECT||WAIT; 2
    Same two lines from your debug log:
    7/25/2011 10:45:39 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
    7/25/2011 10:45:39 PM: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
    Notice any difference? Not a whole lot of stuff is gonna work in DFX if RR isn't loading its exectbl file. Which i believe is your main issue. Dbl check that it is in your skin folder and is in fact full. Got corrupted?
    There is an issue with the DFX installer and W7 or any setup that is using Profile mode, but i can see looking at your debug log that your running the old legacy mode, and should not present any issues here.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jun 2011
    PA
    This may seem stupid but are your skins in C:\users\"username"\documents\riderunner\skins\? or in C:\program files\riderunner\skins? If you haven't updated in 3 years I'm betting they are in program files.
    I am fairly new to ride runner and when I first installed everything was in program files and a lot of things were screwy. I moved all my skin files to profile mode and a lot of things started working better. I don't know why this would make a difference but it did for me.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This moving of file locations was to make RR UAC compliant. According to how MS wants programs set up is that no program under any circumstance is supposed to store any setting type files or any files that will be written to in the program files folder. Which was the way RR used to be for a long time and now known as Legacy mode verse Profile mode of which puts only program type files in the program files folder and all others in your docs\RideRunner folder.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Jan 2008
    well, you helped, but not in the way that you would have expected.
    in the rr installer, one of the options is "install in profile mode" it was checked by default, so not knowing what it was, i had left it checked.
    it seems that is what was causing the problems.
    once i reinstalled and unchecked that option, everything works as it should.
    now i just need to care enough to update all my song metadata so they display correctly...
    Thanks again!!
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Quote Originally Posted by soundman98 View Post
    Yeah, I had to do that when I switched from CF to RR. What a time consuming PITA, but at least everything I have is now good to go!
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    You want to hear a PITA, try having to tag all of your MP3's when you have 45,000! It was a nightmare! 100% of my MP3's are now correctly tagged, have embedded artwork, folder.jpg in each album folder, and around 85% with embedded lyrics. "Tag & Rename" is an INDEFENSIBLE program for this! It just takes lots and lots of time!
    My Fiero Build Thread
    Jan 2008
    my music library seems so small now(5k songs)....
    MySQL Error
    Oct 2004
    there is nothing wrong with profile mode...
    its best to use it...
    the issue is right now, the DFX5.x installer, doesnt see that RR is installed in profile mode
    (this will be fixed when DFX5 installer gets updated, which i think is really soon)
    [long story]
    soundman98, there are NO less features in RR... there are TOOOONS more
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
