Results 1 to 10 of 10
Thread: Little issue with RR. FIgured to ask the experts!
    Newbie NiceLyphe's Avatar
    Jul 2011
    PA
    Alright well I'm using RR as my front end, but when i play music i cannot control the volume/mute in RR. The buttons do nothing. I am using Breakaway in the background as well to filter the music quality and the only way i can lower volume is through breakaway for some reason. Its just a pain to exit the front end and go to breakaway to adjust then go back into RR. Any ideas guys?
    Nov 2009
    I am not sure on this one i had the same issue. I was using breakaway as well and could not get it to work properly. Maby some one can chiime in
    Jan 2008
    time to check the breakaway audio review thread :
    http://www.mp3car.com/the-review-pal...must-have.html
    there are ways to get the volume control to work, but nothing is implemented when it is first installed.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Nov 2009
    Quote Originally Posted by soundman98 View Post
    Seems that no one has found how to get it to work in rr. Have you?
    Jan 2008
    i really haven't tried it much-- i use a external program for audio tweaking, and i use a external volume control..
    but i am downloading breakaway now, and have some ideas. let me get back to you in a couple minutes/hours..
    HID retro--100%
    Jan 2008
    ok, i'm back and dissapointed.
    i cannot get the rr volume control to work with the minimal amount that i know(tweaking settings).. next, i will attempt to screw up my pc by editing the ini file, but it might be best to wait for someone with better programming experience..
    HID retro--100%
    Jul 2011
    PA
    :P you don't have to go through drastic measures if your files will be at risk! I just couldn't figure it out myself either, was wondering if its just not possible..or if i was really not seeing/doing something right. Maybe some one here has got this to work previously, hopefully they speak up :P, I do like breakaway, is there any other program like it I could use yet be able to control the volume?
    Nov 2009
    soundman thanks for the try. I am not sure why no one has tried it. I dont even know where to start. Whos brain should we pick for this one?
    Jan 2008
    bluezx3, and mitch come to mind--either should be able to help more with the in-depth coding that this might require... i just haven't taken enough time to pick apart rr to understand it all yet..
    i will sending a pm to the creator of breakaway very shortly--possibly to see if he can update it to be a little more forgiving on the sound devices it see's(one outside program that will allow volume control is Virtual Audio Cable--VAC, but it doesn't show up in the available list in the breakaway menu)
    HID retro--100%
    Jul 2011
    PA
    Sounds great, let us know if you find anymore information cause I really do like breakaway.
  1. I think i have it mostly figured out.
    By tacobandit in forum Newbie
    Last Post: 12-31-2007, 05:04 AM
  2. Just figured i'd introduce myself
    By PaulieWalnuts in forum Newbie
    Last Post: 11-10-2005, 03:43 PM
  3. Finally figured out the problem...
    By Ashlawn Kemling in forum General MP3Car Discussion
    Last Post: 02-04-2005, 12:41 PM
  4. S-video to rca figured i would ask this time before i buy
    By omlax19 in forum General Hardware Discussion
    Last Post: 05-12-2004, 09:38 PM
  5. OK I think I have figured it out
    By berniejr in forum Power Supplies
    Last Post: 03-03-2004, 11:05 AM
