Results 1 to 8 of 8
Thread: Short cables for Sirius SC-C1 and MJS Gadget
    Nov 2006
    Anyone know where I can get a short (2"-6") version of the DIN cable that goes between the SC-C1 and the MJS gadget? Actually a rigid male-male connector would work.
    I'd go on my own search but I not sure what to call it and how many pins it has.
    Also, is there a chassis mounted socket available for the SC-C1 antenna?
    I'm installing all my components in a chassis and can find most of what I need but I can't find the short DIN cable/rigid connector and a chassis antenna mount.
    Regards,
    Jim
    May 2005
    Good luck with that.
    In the words of Mitch at MJS.. "Adapt!"
    MySQL Error
    Oct 2004
    you would have to make your own cable, and its not that simple, the audio lines inside it are shielded
    but for a short cable... it might be ok....
    i would pin it out... its prob straight...but confirm it
    you only have to do 6 pins, 7 & 8 not used (if memory serves)
    as for antenna... isnt sirius antenna connectors just SMB, i think so
    many options there
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2005
    Quote Originally Posted by mitchjs View Post
    Well you made the thing
    MySQL Error
    Oct 2004
    i didnt make the cable, sirius did...
    i just know what pin does what... not anything more
    (other than its construction, cause i opened one up)
    but this is 3 years ago...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Nov 2006
    I'm all set. I found an outfit online that makes 6" 8-pin cables. They also make other pre-made cables. I alos found SMB to F-type connectors so I can use coax for the antenna connections inside my component box.
    The reason for the component box is that I am using a Fujitsu Lifebook that was laying around as the computer and display head.
    Regards,
    Jim
    May 2005
    Quote Originally Posted by obrienj View Post
    Regards,
    Jim
    Would you mind sharing where you found it?
    I'm still not sure if the SC-SC-USB adapter will even fit in my car, but a shorter cable might help.
    Nov 2006
    CablesOnDemand.com
    Parts No.
    CS-DNPDM8MMX2-001 "CBL MD8 MALE/ MD8 MALE 1'"
    Regards,
    Jim
  1. Short Route, not that short - Nav
    By filatelico in forum StreetDeck
    Last Post: 04-02-2007, 08:39 AM
  2. Where to purchase high quality SHORT rca to mini-phono (1/8" plug) cables?
    By sivart321 in forum General Hardware Discussion
    Last Post: 07-15-2005, 08:59 PM
