Results 21 to 30 of 31
Thread: RR 08-01-2011 Release
  1. #21
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Ok the solution to the post 17 was these lines (big thanks to carputer1 for his help!)
    Code:
    Func _Get_Positions()
    	$ICONS_DIR = @ScriptDir & "\Icons"
    	$rr.Execute("CLCLEAR;ALL")
    	 _FileReadToArray(@ScriptDir &"\positions.txt",$positions)
    	$rr.execute("SETVAR;NUMBEROFPOI;"&_FileCountLines(@ScriptDir &"\positions.txt"))
    	if UBound($positions) = 0 Then
    		$rr.Execute("CLCLEAR;ALL||CLADD;No Position Found||CLSetImg;1;" & $ICONS_DIR & "\Icons\Error.png")
    	Else
    		for $P = 1 to UBound($positions) - 1
    			$P_LIST = $positions[$P] ;positions
    			$rr.Execute("CLADD;" & $P_LIST)
    			$var = StringSplit($P_LIST,"|")
    			If FileExists (@ScriptDir & "\Positions\" & $var[2] & ".png") Then
    				$rr.Execute("CLSETIMG;" & $P & ";" & @ScriptDir & "\Positions\" & $var[2] & ".png")
    			Else
    				$rr.Execute("CLSETIMG;" & $P  & ";" & $ICONS_DIR & "\Position.png")
    			EndIf
    		Next
    	EndIf
    EndFunc ;==>_Get_Positions
  2. #22
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    FYI Mitch just downloaded the daily build from ftp ,,,, notice the "" , quotes are back ,,, for trackpath in video ,,,,
    Thank you
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  3. #23
    MySQL Error
    Oct 2004
    how can that be possible... you need to check your end
    8/16/2011 is latest build
    and in video, trackpath LABEL has no "
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #24
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    mmmm that is strange i'll redownload daily later might of hit the wrong setup exe
  5. #25
    May 2008
    Bordeaux, France
    I have found a little issue into the RRcam's config.ini file:
    I have modified :
    Code:
    Text2Text=LAT: L:GPSLAT LON:GPSLON
    by
    Text2Text=LAT: L:GPSLAT LON: L:GPSLON
  6. #26
    Aug 2005
    Iceland
    I am having troubles with my RR setup. I reinstalled my system few days ago and since then always the same problem. I have reinstalled my WIN7 fewtimes but the problem is still there. When I switch to audio RR hangs up and I have to terminate it.
    Here is a screenshot of the error window and the debug file
    Attached Files Attached Files
    2005 VW Passat FSI 2.0
    Iceland
  7. #27
    MySQL Error
    Oct 2004
    Roadwarrior, without even looking
    HOW about FLASH, is flash player active x installed?
    it doesnt come with windows
    you actually got pretty far.. died when you went to audio
    cant tell you why it died
    but i can tell you dont have proper audio drivers installed
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #28
    Aug 2005
    Iceland
    Quote Originally Posted by mitchjs View Post
    About the flash thing, I can not install RR without install flash, RR will stop the install and tell me that I have to get Flash. ( and i use IE)
    About the audio drivers, first time I had this problem I had installed all updates for win, all drivers, and newest RR and DFX. So reinstalled my system and tried to install RR right away before all updates.
    Is it possible to get somewhere "old" flash version, I would like to try if that would help. That is the only thing that is updated and is diffrent from my previous install that worked
    Edit: I have found the graveyard for the old flash versions
    Iceland
  9. #29
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    For Audio, install the manufacturers latest versions as opposed to windows ones. (Assuming that the manufacturer has done win7 drivers)
  10. #30
    MySQL Error
    Oct 2004
    no, dont use old flash, i dont!
    its not flash, you got too far in the debug.txt
    it dies when you go to audio...
    does winamp work?
    yes, you need audio drivers installed, or you will not be able to fully control audio with RR
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. RR 07-01-2011 Release
    By mitchjs in forum Road Runner
    Last Post: 10-06-2011, 08:32 PM
  2. RR 06-01-2011 Release - its already too HOT
    Last Post: 06-26-2011, 01:30 PM
  3. RR 04-01-2011 Release
    Last Post: 05-18-2011, 11:19 PM
  4. Replies: 21
    Last Post: 04-01-2011, 09:59 AM
  5. RR 02-01-2011 Release
    Last Post: 02-22-2011, 05:46 PM
