A direct copy from the source(s)
PHP Code:
'* This is The Main Module of Road Runner. I tried to keep everything commented, so enjoy.                *
'* LEGAL: You are free to use the code of this application in any way you see fit, as long as you keep    *
*        within the following guidelines:        *
*      1-You may NOT sell all or any part of this code, or any product which is a DIRECT result from it. *
'*      2-You may NOT publish this code as your own, and when posting it you should disclaim its origin.  *
*      3-You can use all or part of this code in your softwarebe that open source or not, and charge   *
'*        for your software, as long as you charge only for the portion of software that YOU've made.     *
'*        In such cases you MUST state that you've used this code and where it was originally obtained.   *
'*      4-You may NOT at any time claim any kind of warranty, penalty or liability over all or part of    *
*        this code, or any of its resulting products.                                                    *
'*      5-You are allowed to charge for holding, distributing or servicing this code, or any resulting    *
*        products from it, as long as you state that:                                                    *
'*          -You're not charging for this software or source code and describe what you're charging for.  *
*          -Where the code was originally obtained.                                                      *
CreditsOriginal Winamp Control Code by Duane Odom 4/12/00haevily modified for use here.            *
'*          Original Serial Port control Code by David M. Hitchner, fairly modified for use here.         *
*          COM code based on sources from www.thescarms.comfairly modified for use here.               *
'*          Phone Control Code made by Hematec/Robby_BMW specifically for RR (Many Special Thanks!)       *
*          MM Directions Code made by 307SW_NLD specifically for RR (Many Special Thanks!)               *
'*          CPU Usage Code by Shame M. Croft -- Memory Info Code from the MCS Project (Modified here)     *
*          Other Credits are available within individual modules (if any).                               *
'*          All users of mp3car.com that have helped with Ideas and Skins for this project.               *
