Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Some Questions about the ART showing
  1. #11
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by mitchjs View Post
    Added to RR
    "FOLDERART" indicator which is the MUSIC File's Folder Image, if exists, fall back attemp to "skinpath\NoFolderArt.jpg"
    hi mitch,
    thanks for your help.
    now i cant wait for the new RR install.
    regards
  2. #12
    Aug 2005
    germany
    Quote Originally Posted by guino View Post
    For the RadioArt, if you're using just the frequency, you can add an indicator to the screen you want to display the art file desired -- i.e. Indicator code: "FILE;$RRPATH$RadioArt\$CURFREQ$.PNG" and then on the load of the screen or on a timer basis on that screen you'd execute "SETVARBYCODE;CURFREQ;FREQUENCY".
    Hi Guino,
    after a long try to get the Station Picture in my Skin i found the reason why it didnīt work.
    The Files in the RadioArt Folder are named....Example 8760...10060 aso. with any commata.
    So i think, the Basic of RR need a File without any commata.
    The Variable of "FREQUENCE" or "FREQUENCY" is written in 87,6....106,6 aso. with commata.
    if i compare both...the file without commata and the variable, the result is nothing. so it found no pic.
    what i can do is, make a second part of RadioStation Pictures with a commata....
    BUT is this what you mean ? or is there another way ?
    i also try it to use the RDS PI information, but most stations have no PI or RR could not show them.
    regards
  3. #13
    MySQL Error
    Oct 2004
    its cause you're in germany, you people use the comma where we use the decimal point
    "frequence" should have a comma in it
    anyway...
    commas or decimal points are NOT used to build filename
    if the frequence is 94.1 or for you 94,1
    the file is called
    frequence 106.2 or 106,2
    if the frequence is 610AM, its:
    if you are finding this not the case, i can set my system to use (ugh) commas
    also its VERY important when talking about radio to tell us what radio module you are using, example "SiLabs"
    (.png, .jpg, or .gif)
    ps I tested with HD Radio & Silabs
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #14
    Aug 2005
    germany
    hi mitch,
    at first...i use a ADS / Silabs radio.
    all what you have written before is correct.
    and you say it yourself....."frequence" should have a comma in it
    Guino gives me for loading the RadioArt pic the line
    this line means, load "Frequence" and shift it into "Curfreq". and it shift the comma too.
    but in my radioart folder is no pic with a comma or dot saved.
    for basic RR working it need a file without it. the dot or comma you build inside the RR code.
    i dont want to change it, i only ask...is there a label or whatever where is written the basic form of "frequence".
    as i take a look inside my radio.ini file i see the last frequence i used in my radio. is it possible to work with this value ?
    and what is his name ?
    regards
  5. #15
    MySQL Error
    Oct 2004
    i am at a loss, radioart is radioart...
    there is no lable in rr, that doesnt have the comma or decimal point for frequency
    if you want one, i suggest doing a eval on it, and multiply by 100
    "eval;LCURFREQ;$CURFREQ$*100"
    LCURFREQ now would be as example 10610 if FREQUENCY = 106.1
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. MEM tag showing 165%
    By 01black_ac in forum Road Runner
    Last Post: 11-27-2008, 08:07 PM
  2. POI not showing
    By astrapc in forum CF SDK
    Last Post: 01-13-2007, 05:51 PM
  3. POI not showing in CF
    By astrapc in forum GPS
    Last Post: 01-06-2007, 08:55 AM
  4. GPS not showing up
    By KennyKen in forum Road Runner
    Last Post: 07-02-2006, 04:46 PM
  5. I am showing a PM
    By alexg047 in forum Mp3car Forum Suggestions/Comments
    Last Post: 08-12-2003, 10:13 AM
