Results 1 to 8 of 8
Thread: Can you go back to main menu just by closing an application without a button press?
    FLAC -zip-'s Avatar
    Ontario/Canada
    Hi Guys,
    I have Dashcommand and use a simple application skin to embed it .
    Dashcommand is a fullscreen application and has its own exit button. Is it possible to just close the application and RideRunner will go back to the main menu somehow? Right now I have it where the application closes, then I have a single button on a black application screen that I press to exit and go back to main menu.
    Sound Stage
    Eclipse|MTX|Infinity
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Well, if it's a full screen application, simply use the RUN command to execute it from the main menu, it should run on top of RR and when you close it, you'll be right at the main menu. If you're running it from a different screen, you can try "RUN;<path>\dashcommand.exe||MAIN" so that it runs it and returns to the main menu (that way when you close it it's already on the main menu).
    Ride Runner RR's Myspace
    FLAC -zip-'s Avatar
    Ontario/Canada
    Thanks a ton G!!! Makes perfect sense
    Sound Stage
    Feb 2011
    i know the post is a little outdate but i'm still interested in this question;
    i have some applications embed that have their exit button, is possible / exist an event that act when the application embed is closed?
    Something like:
    You open a .skin and load an application, when the application is closed then send command (for example back to the last page)
    Is this possible?
    (the trick "RUN;<path>\dashcommand.exe||MAIN" will work only for fullscreen NON embed applications)
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This could very easly be added as a ONxx event. I will add it for the next release....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jun 2011
    PA
    I think using RR extended plugin you can do a command for 'on application start' and 'on application end'
    May 2005
    Rochester, NH
    Sweet. I hadn't looked into this much yet as I just installed dashcommand but had noticed it was behaving weird. Anything to help streamline is excellent!
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    As dlane2155 pointed out, RRExtended does have that feature, events for when applications startup or close. I wasn't sure if you wanted to go with that, I could have at least mentioned it I guess... It is my plugin after all. Hehehe
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Resume always comes back to main menu
    By EricE in forum Road Runner
    Last Post: 12-14-2008, 08:39 PM
  2. Get skin to Autoswitch back to Main Menu?
    By antimatter in forum Road Runner
    Last Post: 07-01-2008, 02:23 AM
  3. Replies: 15
    Last Post: 08-03-2006, 07:02 PM
  4. Replies: 5
    Last Post: 03-14-2005, 01:41 AM
  5. Trouble going back from TV to Main Menu
    By Balki in forum RR Bug Tracker
    Last Post: 03-11-2005, 06:25 PM
