Results 1 to 3 of 3
Thread: icon transparency in list
    Oct 2010
    Ivry-Sur-Seine (France)
    I have problem with transparent icons in lists
    if I use that line (as CARWINGS lite) no problem the icon is transparent :
    IL,DL,transparent.bmp,sel.bmp,,0,50,60
    S,140,85,519,439,0,0,0,0,0,0,255,255,255,255,255,2 55,128,128,128,0,0,0,true,20,"Arial"
    (cf image 2)
    if I change the font, the icon is not transparent.
    S,140,85,519,439,0,0,0,0,0,0,255,255,255,255,255,2 55,128,128,128,0,0,0,true,20,"Digiface"
    (cf image 1)
    Also if I change the font size
    S,140,85,519,439,0,0,0,0,0,0,255,255,255,255,255,2 55,128,128,128,0,0,0,true,22,"Arial"
    (cf image3)
    one would have a solution?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You seem to be having some issue I'm not seeing here...
    This worked fine here (Just copied/pasted your line) -- got transparency as it should:
    I also tried this and it again worked fine (Different font and size, below screenshot):
    S,140,85,519,439,0,0,0,0,0,0,255,255,255,255,255,2 55,128,128,128,0,0,0,true,30,"Ericsson GA628"
    I can only assume this issue may have to do with the DirectX version and/or video card driver -- I assume those are all iLists ?
    Ride Runner RR's Myspace
    Oct 2010
    Yes I use Ilist.
    I downloaded the lastest drivers for the graphic card and directx but I still have the same problem.
    I specify that this happens on XP with seven I do not have this problem.
    Thank you
  1. CFX TX (Transparency Revolution)
    By MatrixPC in forum RR Skins No Longer Supported
    Last Post: 08-27-2009, 07:24 AM
  2. Icon into a Custom List..HowTo?
    By Serfio in forum Road Runner
    Last Post: 04-28-2009, 08:25 AM
  3. Transparency help...
    By marazi in forum RR Skins
    Last Post: 09-21-2006, 12:49 PM
  4. Transparency
    By r600rkt in forum Road Runner
    Last Post: 08-29-2006, 02:10 PM
  5. Transparency for album art
    By F350 in forum Road Runner
    Last Post: 06-13-2006, 04:22 PM
