Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: RR 09-01-2011 Release
  1. #21
    MySQL Error
    Oct 2004
    yea.. i dont know what that could be, hide controls is complicated to begin with
    its not high priorty right now.. but i will give it a look
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #22
    Jan 2006
    crashing on startup -loading skintool...
    My RR is crashing on startup,
    it says loading skintoon..
    Attached Files Attached Files
    Last edited by Blue ZX3; 10-02-2011 at 03:29 PM. Reason: I put the debug log as an attachment
  3. #23
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    check your skin folder for a Skin.ini
    its either missing or corrupted
    01/10/2011 22:42:31: LoadSkin: C:\Program Files\RideRunner\Skins\idr2\
    01/10/2011 22:42:31: WARNING: Could not find Skin's Skin.ini file. [Possibly missing, corupt, or not used by skin]
    01/10/2011 22:42:31: WARNING: Path Used: C:\Program Files\RideRunner\Skins\idr2\Skin.INI
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  4. #24
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    A skin isn't required to have a skin.ini, and why i added that last part on the warning, "or not used by skin". Aside from that, I don't see anything that would cause it to not load..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #25
    MySQL Error
    Oct 2004
    generic reply would be:
    test with carwings
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #26
    Dec 2007
    Sydney Australia
    I have my screen set as 800x480 (native res and display res) and I am getting the bottom part of RR cut off, even the startup screen.
    During startup I cannot see the status display lines in the bottom right corner and on the RR screens I cannot see the control bar or the "more>" selection at the bottom.
    I have gone into RRConfig and set display to 800x480x32, aspect ratio to 16:9 and I am using the Carwings default skin.
    When I set the screen res to 800x600x32 all is ok.
    What have I missed ?
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  7. #27
    MySQL Error
    Oct 2004
    Quote Originally Posted by RevheadKev View Post
    telling rr to display that skin, at a resolution that its not designed exactly for...
    in general.ini
    for the skin, you will see
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=600
    set showheight to 480
    its gonna look out of aspect
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #28
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    I know this is going back a little, but would this be a possibility? I'm assuming this pic is a photoshop since I doesn't seem to work for me.
    Quote Originally Posted by GF-ler View Post
    thanks for it.
    my biggest wish is, to bring the MediaArt Picture behind the browserlist.
    donīt no if its possible for RR.
    i saw it once in the FSR skin.
    regards
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  9. #29
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I's not very important but i have found a little issue with the GPS2City plugin.
    Systematically , it create a GPS2City folder under the plugin folder and not a RRGPS2City (bad name plugin checked into this plugin may be ?)
  1. RR 07-01-2011 Release
    By mitchjs in forum Road Runner
    Last Post: 10-06-2011, 07:32 PM
  2. RR 08-01-2011 Release
    Last Post: 08-28-2011, 02:41 PM
  3. RR 06-01-2011 Release - its already too HOT
    Last Post: 06-26-2011, 12:30 PM
  4. RR 04-01-2011 Release
    Last Post: 05-18-2011, 10:19 PM
  5. Replies: 21
    Last Post: 04-01-2011, 08:59 AM
