Results 1 to 7 of 7
Thread: Mute Destinator in RR
    May 2011
    Hi
    Hoping someone in this section can help me.
    Is there a way to mute the Destinator voice in RR? Music player and Destinator share wave input so the destinator mute button mutes music playback as well.
    Jeff
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    This link post #5 can help you . You need just to replace the drive.exe by the navigator's exe sygic mute option
    Nov 2004
    St Louis
    When I read the OP, I assumed you want to mute Destinator without muting the music, Is that right?
    What version of Destinator are you using?
    May 2011
    Quote Originally Posted by GizmoQ View Post
    GismoQ Thanks, yes I want to be able to have Destinator running and listen to music without spoken directions on top The Destinators own mute button is fine if listening to radio as it mutes wave, but if using mp3 playback it mutes this as well.
    I am using 9.0.10.101
    I had a quick look at the link given by pierrotm777 but I think thats only to mute music when nav speeks
    Nov 2004
    St Louis
    I believe the easiest workaround is to go into the voice directory and create a new voice folder with nothing in it. When you want no voiceover switch Destenator's active voice to the empty voice.
    May 2011
    Nick thinking GizmoQ, an empty folder 'None' in 'Voice' gives the option to stop voice, Thanks.
    Not the perfect one-button off-on, but OK for me as I rarely have the voice on.
    There is probably a way to set up command to toggle voice in Destinator.ini, but that is beyond me
    Jeff
  1. Know of a way to mute a car deck with 3.5mm output and no mute out?
    By Mysticle31 in forum General Hardware Discussion
    Last Post: 06-09-2009, 11:38 AM
  2. Mute the destinator sound
    By clemen in forum Centrafuse
    Last Post: 08-30-2006, 05:40 PM
  3. Mute Doesn't Mute on M10k?
    By LiquidKernel in forum Car Audio
    Last Post: 08-22-2006, 03:12 AM
  4. Destinator and Frodoplayer control and mute
    By Mrbmw99 in forum Map Monkey
    Last Post: 02-24-2005, 12:41 PM
  5. Mute winamp during destinator speech
    By Ninja Monkey in forum GPS
    Last Post: 05-20-2004, 01:59 PM
