Results 1 to 10 of 10
Thread: Integer or Round function with RR
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile Integer or Round function with RR
    I create a value (DFXSPEEDINPERCENT) with an other but i should like to obtain the Round or the Integer of this value.
    Code:
    EVAL;DFXSPEEDINPERCENT;$DFXSPEED$/65535*20
    How can i do that with RR .
    Oct 2010
    Ivry-Sur-Seine (France)
    I think it will you use RREXTENDED PI and the function RNDVAR
    "RndVar;<VALUE TO ROUND>;<NUMBER OF PLACES>;<RESULT VAR>"
    * $MYVAR$ = 15.458468413874
    Example: "RndVar;$MYVAR$;0;RESULT"
    Result: RESULT = 15
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    use \ for integer division: EVAL;DFXSPEEDINPERCENT;$DFXSPEED$/65535*20
    Ride Runner RR's Myspace
    May 2008
    Bordeaux, France
    Quote Originally Posted by guino View Post
    Like that ?
    EVAL;DFXSPEEDINPERCENT;$DFXSPEED$\65535*20
    My label is that:
    Code:
    L,20,218,300,34,169,197,209,22,"Arial:BI","=$DFXSPEEDINPERCENT$||=%","LEFT",,"DS=2,2,0,0,0"
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I'm not too sure on that one, I THINK it should be / I have never seen a forward slash used for division..... Even in the example he is using the /, which looks correct.
    My Fiero Build Thread
    May 2008
    Bordeaux, France
    In fact,
    EVAL;DFXSPEEDINPERCENT;$DFXSPEED$\65535*20 don't run
    So where i use the \ please ?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    \ is integer division, / is float point division, so you did in fact replace it as I meant you to do (sorry for not replacing it myself on the example), the issue you're probably getting however is the math involved with integer division (if you get any number less than 65535 and do an integer division by 65335 you get ZERO), so try THIS:
    EVAL;DFXSPEEDINPERCENT;($DFXSPEED$*20)\65535
    Alternatively, this should be equivalent to rounding a number:
    EVAL;RESULT;MYFLOATVAR\1
    If MYFLOATVAR = 1.23 then RESULT=1
    If MYFLOATVAR = 1.57 then RESULT=2 (it will get rounded - there are ways to make it not round it off)
    If you use this method you can do all your calculations as usual, then at the end just get the result and round it off.
    May 2008
    Bordeaux, France
    Wonderfull Guino,
    I confirm that :
    give me well an integer result :-)
    I suppose that if i want a result updated each second i must to use a timer ?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Unfortunately, yes... I think it's time we add an "EVAL" label code so that you can place complex stuff into labels directly.. we'll have to add a way to allow label codes directly in the expressions though..
    May 2008
    Bordeaux, France
    Cool,
    may be for the november release ?
  1. Budget SSD Round-up
    By Penzance in forum CarPC News
    Last Post: 09-10-2010, 06:30 PM
  2. Replies: 3
    Last Post: 10-30-2007, 12:14 AM
  3. FS: 17" ROUND LCD Monitor!! YES, ROUND!!
    By Motorcity in forum Classified Archive
    Last Post: 03-31-2006, 10:09 PM
  4. A big round of thank you.
    By Darmie in forum General MP3Car Discussion
    Last Post: 03-27-2006, 10:11 AM
  5. Opinions on round two....
    By Psychobiker in forum Fabrication
    Last Post: 11-12-2005, 07:01 PM
