Quote Originally Posted by pierrotm777 View Post
Try :
install foo_runcmd.dll f2k components
use this command lines in exectbl.ini
"NAVPAUSE","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Playback/pause"
"NAVRESUME","run;C:\Program Files\foobar2000\foobar2000.exe" /runcmd="Playback/play"
found here
seems to work now, finally
there is a small defect or some times mute the late .. but being that I'm trying everything on the virtual machine, I am convinced that the problem stems from them.
thank you for helping me. was a month that I went crazy to solve this problem ..
