Results 1 to 9 of 9
Thread: ONRESTORED Carwings_Dynamic_Lite
    Oct 2010
    Ivry-Sur-Seine (France)
    When I launch RR with the skin Carwings_Dynamic_Lite, I saw in the debug.txt the command ONRESTORED and a lot of SETVAR like this:
    Executing: ONRESTORED
    Que Exec: Vrai, menu.skin, SETVAR;SKINORIGWIDTH;800||SETVAR;SKINORIGHEIGHT;60 0||SETVAR;SKINSHOWWIDTH;800||SETVAR;SKINSHOWHEIGHT ;600||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION ;0", Faux
    Executing: SETVAR;SKINORIGWIDTH;800
    Que Exec: Vrai, menu.skin, "SETVAR;SKINORIGHEIGHT;600||SETVAR;SKINSHOWWIDTH;8 00||SETVAR;SKINSHOWHEIGHT;600||SETVAR;SKINXPOSITIO N;0||SETVAR;SKINYPOSITION;0", Faux
    Executing: SETVAR;SKINORIGHEIGHT;600
    Que Exec: Vrai, menu.skin, "SETVAR;SKINSHOWWIDTH;800||SETVAR;SKINSHOWHEIGHT;6 00||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0 ", Faux
    Executing: SETVAR;SKINSHOWWIDTH;800
    Que Exec: Vrai, menu.skin, "SETVAR;SKINSHOWHEIGHT;600||SETVAR;SKINXPOSITION;0 ||SETVAR;SKINYPOSITION;0", Faux
    Executing: SETVAR;SKINSHOWHEIGHT;600
    Que Exec: Vrai, menu.skin, "SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION; 0", Faux
    Executing: SETVAR;SKINXPOSITION;0
    Que Exec: Vrai, menu.skin, "SETVAR;SKINYPOSITION;0", Faux
    Executing: SETVAR;SKINYPOSITION;0
    Que Exec: Vrai, menu.skin, "ONSTART", Faux
    So if I launch my skin I don't have these commands SETVAR, I've ONRESTORED and ONSTART.
    Where are these commands in the skin Carwings, I look in exectbl.ini but I don't saw nothing.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    ONRESTORED should only be executed when restored from a minimized state.
    It's possible there is a plugin that is sending those commands when it gets the ONRESTORED command.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    do you have rrextended plugin install that looks like thats where this is comming from
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Oct 2010
    Yes I use RRextended but in this case there should be these commands regardless of the skin used
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    this could be true, but i know most functions in rrextended are switchable , so its possiable this section is switched on in 1 skin but not another.
    i actually have rrextended here so i tested to be sure , and sure enough it is rrext.
    theres a setting for rr.ini or skin.ini to switch this section on/off
    rrskingen_enabled= (True/false)
    Oct 2010
    Carputer1 you're too strong, you put your finger exactly on the right variable.
    Thank you very much for your help.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    lol no problems glad to help
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    thats not the case , you'll find its fired on rr start up as well... i have seen it fired at different times ,, and not just on restore from minamize
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, it does fire at startup as is part of the window initz proceedure... its just like the window resize funct gets called before a window is actually shown for the first time....FYI.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Carwings_Dynamic_Lite Add_ONs -II-
    By pierrotm777 in forum RR Skins
    Last Post: 09-28-2014, 04:14 PM
  2. RRLanguage.NET The multi language for Carwings_Dynamic_Lite
    By pierrotm777 in forum RR Released Plugins
    Last Post: 07-19-2011, 10:11 AM
  3. Carwings_Dynamic_Lite Add_ONs
    Last Post: 07-14-2010, 02:42 AM
