Short answer . . . . . . . yes.
RR.ini's skin= will only be used on first start up.
If you change the skin while RR is running normally you would want that to be used the next time you run RR. You wouldn't then want it to go back to what the default is there.
the default is there so that you have a good working skin should the skin you change to crashes RR.
LinkBack URL
About LinkBacks
