View Poll Results: Would you like to be able to set transitions dynamically? (ie right b4 screen change)
Voters
4. You may not vote on this poll
  • Yes
    4 100.00%
  • No
    0 0%
Results 11 to 20 of 30
Thread: dynamic transitions possible???
  1. #11
    Jun 2011
    PA
    Quote Originally Posted by RipplingHurst View Post
    I'd love to see this working...
    I think I might have it now. The menu.skin is throwing it off I think because it is not discardable. I'll post an update soon.
  2. #12
    Jun 2011
    PA
    I could have this working except for one of these two commands are required; RELOADALLSCREENS or UNLOADALLSCREENS
    RELOADALLSCREENS disables gestures
    UNLOADALLSCREENS disables transitions
  3. #13
    Jun 2011
    PA
    I am lost now. No matter what when switching directions it does not want to work. Maybe a new feature like this can be implemented into a future RR release or maybe someone else can figure this out and make a plugin or share their codes.
  4. #14
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Hopefully Guino and Mitch will help you solve this issue one way or the other! I have buttons to change/navigate pages, I could design a much better skin without those mostrosities, make all skins look like an ATM machine, IMHO. The way iOS, Android, and now Windows 8 do it is so much better.
  5. #15
    Jun 2011
    PA
    I agree, and I'm close just the looping is what is causing it to have problems. I have tried everything I could think of, but something is not right. I could probably have it so there is a start page and an end page with no looping and it would work flawlessly I think. I'd have to mess around with it again to make sure. The gestures are no problem, they work each and every time. It's the dynamic transitions that is giving the problem. But I think something new should be implemented, and maybe some more options for transitions. For example if you have media controls or labels on your screen which do not change for the next screen, make it so you can have a "transition area" that is only applied to that part of the screen.
  6. #16
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    "EFFECT" - This allows you to dynamically select the effect used when trasitioning FROM the current screen to another.
    Example: "EFFECT;0" (fade) -- check /EFFECT skin parameter above for range of values.
    Ride Runner RR's Myspace
  7. #17
    Jun 2011
    PA
    Quote Originally Posted by guino View Post
    I don't know how I missed this in the skin commands.txt, unfortunately it has the same problem when navigating to a screen which has been previously loaded.
  8. #18
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'm not sure I understand what that issue is. To be honest, the feature with effectin/out never made much sense to me (you're always going INto a screen and OUT of another at the same time), the distinction made is if you are going to a screen that you've browsed before the one you're currently in, then you're going "out" of it - note that this is unrelated to the screen being loaded as the previous screen could have been discarded. So I am not 100% sure of how the logic was supposed to be for these, however, you can try setting transition=-1 on skin.ini or rr.ini and then use the effect command to set the transition from one screen to another (should not matter if the screen is loaded or not) - you can also use /EFFECT in the skins to define it to whatever, but for dynamic changes it would get messy. The only thing the screen being loaded or not will change is that when you load a screen it sets the effect based on the ini settings (transition[in/out]) and resets everything on the screen, as opposed to keeping it loaded preserves the last state.
  9. #19
    Jun 2011
    PA
    What I have found is there is maybe a memory order to it. Say you are starting on screen 1 and then go to screen 2. It will always do the IN EFFECT for screen 2. If you are on screen 2 and then LOAD screen 1 it will do the out effect of screen 2. This is fine if you are only using gestures, but once you start adding in buttons as well it gets confusing. I think this is more useful for applications, where you just load the application and it will do the IN effect, then when you use the BACK command it will do the OUT effect.
    I think I have figured this out using the EFFECT;X command however it seems to only work with screens which have already been loaded, preloaded screens do not count. I'm not sure why this is.
    I think if I set up an on skin start command where it goes through a sequence of loading each screen perhaps off the visible screen, then the transitions will work the way they should. I'll post more after I test this.
  10. #20
    MySQL Error
    Oct 2004
    id also think a .skin with a /EFFECTxxx = command would override
    so if your doing some funky stuff, i wouldnt have any /effectxxx commands in them, unless its a popup
    i think i know what you want to do, swipes to go back and forth, like viewing images on iphone
    you might be outside the box on what we have in RR
    so good luck
    i like transitions for a while, then i dont use em for long
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. Help with Flash CS3 and transitions
    By monkeyracer in forum RR Skins
    Last Post: 04-07-2008, 01:48 PM
  2. how do you control transitions in .Net
    By Hockeynut in forum DigitalMods (Scripts / API)
    Last Post: 03-19-2008, 11:00 PM
  3. Request - screen transitions
    By lbridges in forum Road Runner
    Last Post: 12-29-2007, 02:00 PM
  4. question about transitions
    By tundra2000 in forum Road Runner
    Last Post: 01-23-2007, 08:58 PM
  5. Transitions
    By wizz in forum Road Runner
    Last Post: 09-06-2006, 11:22 AM
