Mitch is going to need a lot more information than that.
The rr.ini's for example, plus dome debug.txt's.
Also make sure you are testing with the carwings skin.
A better description of what is or is not happening plus some screenshots maybe.
HI Mitchjs , I have tried RR with home computers and it works well. Then I took the RR.ini CarPC and I put it in the home PC and it works, but it does not work if I put the rr.ini from home pc and put it in the carpc .... the CarPC has been formatted and I use W7 Pro but the problem exists in XP too .... however this is the config CarPC ......
Sri but my English is very poor....
Ok Enforcer, I will do that....
This is the error I have when load RRconfig
going to need your rr.ini
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
I've installed RR yesterday for the first time and looks like I'm having the problem.
When I try to open RRConfig it gives me the same .NET error and trying to open the radio section also gives me errors.
Also when I try to save the configuration it gives a .NET error and the changes are not saved.
It is a clean install of RR on a clean installation of Windows 7 32-bit.
Attached is the rr.ini.
Any suggestions?
same net error in italian?
i tested that rr.txt(rr.ini) and works fine
i would suggest its not the same net error
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
I'm running a Dutch version of Windows and getting the errors in dutch.
This morning I've did a clean install of an english installation of Windows 7 32-bits. Installed Ride Runner in english and still getting the same error message (RRError.txt).
When I click on one of the nodes in the radio section, the RRErrorRadio.txt is shown. Looks like it's something with ini settings of the radio.
I'm doing the default installation of RR and only adding the HD Radio module (without is the same problem). I've also attached the rr.ini again.
Ok, i've found it.... Stupid me
RRConfig crashes with this error when no soundcard is available.
I've been installing it on my machine with the onboard soundcard disabled, because I use an USB soundcard. Didn't had it connected.
After taking a sneak peak within RRConfig with Reflector I've found a mentioning of "soundcard lines" which triggered me.
Ok, I think was the same problem I have had because I was trying in the same mode, without the soundcard because I use a usb soundcard like you....
