Enforcer, you can give this one a try for Great Britain. Make sure to back up the original zips.dat of course
Either one of these, France and England, are only going to be as good as the data that is supplied in that database of course.
pierrotm777, Give this a try and see if it works for France. I used that site you linked to, and think that I have it set up correctly.
BACKUP YOUR ZIPS.DAT BEFORE PUTTING THIS ONE IN THE RR FOLDER.
If this does work, then it is a viable solution for the countries available on that site.
My Fiero Build Thread
not to mention, the plugin doesnt use the zips.dat file in the RR root!
it uses the one with the plugin...
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Yet another change that I didn't know about I guess![]()
yes the zips.dat goes in the main plugin folder, NOT the profile mode documents folder.
Live mp3Car Facebook Chat
I mentioned this before and you did not respond about it. Are you using the LOCATE command or do you have LocalDataCaptureInterval=1 in rr.ini? You MUST use one or both to get the labels to populate.
I have just tried the LOCATE command !
But i had not seen that i have already the LocalDataCaptureInterval=1 option into my rr.ini file !
ok, then the next question i have is does your latitude and longitude use decimals or commas
