Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: GPS2City Zips and Such
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I try to play with the plugin RRGPS2City .
    I try to see something into the labels =$CURRENTZIP$ , =$CURRENTCITY$ and =$CURRENTSTATE$ .
    My position is :
    Lat = +4.862143 , Lon = -74.415130 .
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by pierrotm777 View Post
    My position is :
    only works with US zip codes
    Live mp3Car Facebook Chat
    May 2008
    Bordeaux, France
    I know that and i simulate a us track with my gpsgate , but i see nothing
    May 2008
    Bordeaux, France
    It's possible to know how this plugin source run . It's possible to have the source for adapt it to the world ?
    Woodbridge, VA
    Blog Entries
    55
    the source is the zips.dat file that should be included with the plugin. Open that file and you'll see a sequence of zip codes with their associated information. If such a database existed for the entire world, it could be easily adapted.
    Also, in order for the labels to populate you have two options. Either run the LOCATE command, or go into the rr.ini file and set localdatacaptureinterval to 1. This will update the labels once per minute.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It's possible to do it for other countries but you would need internet access.
    I do this sort of thing in Fuelprices.
    May 2008
    Bordeaux, France
    Sorry for my first gps coordinates that was bad
    My test is:
    +40.693644,-75.224714
    I have build a zips.dat file for the france with the same format but , that don't run !
    Attached Files Attached Files
    Woodbridge, VA
    Blog Entries
    55
    sure, it could be done via geocaching, but that would require full time internet to be reliable. Consider that when i first made this feature available to RR back in like 2006, internet was in short supply in the car
    Woodbridge, VA
    Blog Entries
    55
    My test is:
    your file does not have the proper categories, pretty sure you need 7 columns, you only have 5
    The plugin works just fine. Just tested it. All i did was install the plugin, start RR, run LOCATE command and CURRENTCITY populated "Centreville"
    Again, if a public database, online or offline, were available this plugin could be a bit more flushed out. I could query the nearest 100 zip codes each time internet were detected for example, but i do not have any information on where that would be available.
    May 2008
    Bordeaux, France
    I think that this link would be your best friend !
    http://download.geonames.org/export/zip/
  1. Zips.dat file for the FRANCE
    By pierrotm777 in forum Road Runner
    Last Post: 01-24-2009, 12:18 PM
  2. Replies: 19
    Last Post: 07-24-2008, 12:13 PM
  3. zips
    By Mini Sumo in forum Road Runner
    Last Post: 10-09-2007, 02:27 PM
