Results 1 to 10 of 10
Thread: including a button for record
    Sep 2011
    hi, i'm using the webradio plugin and fitted it to my needs to use it with elite 2 skin. is there a simple way to record web streams as in centrafuse? i would like to include a button for this! thx in advance.
    suavecito's Avatar
    Jan 2008
    Atlanta, GA
    Fruch,
    The eLite 2 private beta includes the ability to record webradio, radio, or sat radio, however it uses the plugin from EL CAMINO, RRec [Audio Capture]. As far as I know, this is the only way this will be possible for now. If you set your recording device default to "Stereo Mix" or "What I Hear", you should be able to record any audio, web-stream audio that your computer plays back.
    Sep 2011
    thank you. i'm awaiting the new elite 2 beta like nothing else, but i want to extend the functions of rrwebradio plugin. you said, you're using RRec, but last state is that it isn't working with win 7. does yours work? and how have you get it to work?
    and please let me know if you changed the file "Top-Round.elite" compared to the alpha release. further it would be good to know if we can use the files in elite/menu folder from the alpha release in the new beta.
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Well,...... I asked for this option awhile back about adding a record button to a certain skin which I won't mention. It's called "Stream Ripper" plug/add-on for Winamp. Here is the link -----> http://streamripper.sourceforge.net/ It's free, works excellent and I still use this to date. This automatically loads up when winamp is loaded, which RR uses anyway. The only problem is it's small buttons and you have to minimize RR to get to the streaming window to turn record on/off. Yes,... this would be nice to add this for all RR skins. good luck.
    Sep 2011
    thank you for the hint. as you said it's not the cleanest solution! i'm prefering a command to use it in all skins, too.
    i would like to embed the function in my modified radio skin of elite 2:
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    not trying to hijack this thread, ( just a little ) but BASS player PI, does this with a simple command, and has a WebRadio built in.
    Sep 2011
    yeah, i visited the BASSRR thread before, and it has really awesome features. but i'm a winamp fanboy maybe i'll have a look at it when i install newest RR release.
    Sep 2011
    i don't want to start a new thread, since the topic is similar:
    how can i create a button like --> once pressed --> command1 ---> twice pressed --> command2? if it's not clear what i mean: i want to realize a record button for dvbviewer plugin which starts recording on first press and on second press it should stop recording. i don't want to make separate buttons - i need the space for other buttons. is there any tutorial or short explanation? thx
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by fruchtfliege View Post
    SET a variable with the SETVAR command, then use the BYVAR command attached to that variable to create a toggle button.
    Something like SETVAR;RECORDVAR;0 in ONSKINSTART on exectbl.ini, then your button command would be:
    Code:
    BYVAR;RECORDVAR;RECORDCOMMAND||SETVAR;RECORDVAR;1<<STOPCOMMAND||SETVAR;RECORDVAR;0
    no spaces in the command
    Live mp3Car Facebook Chat
    Sep 2011
    thx mate. is it also possible to load another img to change the button when it's recording? i really have to learn more about variables
  1. Just for the record
    By Das in forum Linux
    Last Post: 05-29-2006, 09:09 PM
  2. WTB: A whole CarPC for a BMW e46 (including dash bezel)
    By jamesbond007 in forum Classified Archive
    Last Post: 07-14-2005, 04:49 PM
  3. Xenarc size, including caseing?
    By Maņana in forum LCD/Display
    Last Post: 08-16-2004, 12:28 PM
  4. Lilliput size, including caseing?
    Last Post: 08-02-2004, 06:16 PM
  5. FA: Assorted stuff (including an SBC and TFT)
    By r0cket- in forum Classified Archive
    Last Post: 03-06-2002, 02:50 PM
