Results 1 to 5 of 5
Thread: Directory Lists and hiding sub folders?
    Jun 2011
    PA
    Question Directory Lists and hiding sub folders?
    Is there anyway to hide folders in a directory list, so that it only shows files in that folder, and no option to go into sub folders?
    MySQL Error
    Oct 2004
    YES
    take a look at history.txt "2/4/2011"
    "OPT_FILESONLY" - show only files.
    its the SD definition, that will set this
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    RR isn't supposed to display files with the hidden attribute (so you could hide items you didn't want showing), however it seems that when we (I) did some unicode support I ended up removing that feature - I have re-added this to the software for next release. Bear in mind that when you add folders to the player, it's the player plugin decision on whether or not to load/process hidden files - ideally you should only keep the stuff you want to load/view in these folders. If you have some very odd structure/requirements, the only thing that may help is a Browse.rrl which would allow you to show as much/as little as you want of folders/subfolders - but even then you may need to move stuff around. If you just want to show the FILES of a folder, I would suggest making a playlist (with the songs in the folder) and browsing into that instead of browsing into the folder itself.
    Ride Runner RR's Myspace
    Jun 2011
    PA
    Alright thanks mitch and guino. I will give what mitch suggested a try. This is for a cd player skin so hiding the folders isn't really an option. I may end up making it so the cd player skin wont open unless the media type is a cd using the byvarx;mediatypeinserted
    Thanks again
    Jun 2011
    PA
    I got this working how I want now. While I did not use the suggestion mitch made, that is still useful for future reference.
  1. Problem with playlists/directory lists
    By Konrad in forum Road Runner
    Last Post: 09-16-2009, 02:11 AM
  2. Replies: 3
    Last Post: 06-18-2008, 08:52 AM
  3. Replies: 0
    Last Post: 11-08-2004, 08:07 PM
  4. Hiding LCD
    By Dragon S5 in forum LCD/Display
    Last Post: 04-06-2004, 12:48 PM
  5. Hiding LCD
    By kmoosad in forum LCD/Display
    Last Post: 02-27-2004, 10:37 AM
Tags for this Thread
