Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
Thread: RR 11-01-2011 Release
    MySQL Error
    Oct 2004
    Where is this year gone... November already
    Download Here: http://www.nisuautomotive.com
    Just some Tweaks!
    FLASH 11.1.102.55 has been released by adobe, and its is compatable with RR's transparency.
    feel free to use
    Stay on FLASH 10.3 (see sticky), Flash 11 is a major change by adobe, and objects no longer are allowed to be
    rendered transparent, when using a non browser application, this is a fundamental change by adobe.
    we are looking at a new approach to flash objects
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    10/28/2011
    + Setting; "RRRadioSearchPresetsMain" determines of radio "searching for presets" will
      happen on the MAIN list(true) or auto switch to the LOCAL list(false)
      ex. RRRadioSearchPresetsMain=false  (default)
    10/26/2011
    + Skin Label; "RRAppName" returns the embedded application window information
    + User Var; "RRAppName" returns the embedded application window information
    10/20/2011
    # fixed issue with "minus1" introduced with ML
    10/13/2011
    # Prevention of hidden files from showing in DL
    # fixed DL folder issue with "." in the name
    # In DLs, songs turned into general list items (due to ML)
    10/9/2011
    # Audio Player; Windows Media Player, fix for visualization window showing before enabled
    # RRConfg, fixed .net assembly unload during plugin discovery
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Cool, i can't wait !
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    nice thanxxxxxx
    May 2008
    Bordeaux, France
    Does exist a possibility to change the speed for the EFFECTIN OUT function !
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    So many changes I need to be figuring out as I re-do my skin... eek! Good work though!!
    With the ML, would there be a way to have a section of text right aligned? Not just so many pixels from the right side (%TextX=-25%). That works great for a standard size field like the year, but wouldn't work for an Album title.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
    Nov 2004
    St Louis
    Quote Originally Posted by sargeants View Post
    Makes for a lot of interesting programming ideas. Can't wait to test it.
    May 2005
    There seems to have a problem with the code that loads the loader.skin. I have the following "RRVER" and "STATUS" label which now shows up as very small fonts.
    L01,8,11,120,25,0,0,0,14,"Microsoft Sans Serif:B","RRVER","LEFT"
    L02,150,460,500,35,255,255,255,22,"Calibri:B","STA TUS","CENTER"
    May 2008
    Bordeaux, France
    Quote Originally Posted by RS200Z View Post
    I have often the same issue:
    You can change your font to arial without :B !
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Loader issue is fixed in next release.
    Check your loader.skin if you have line like this,
    /, L, x, y, w, h,....
    Remove it for now.
  1. RR 07-01-2011 Release
    By mitchjs in forum Road Runner
    Last Post: 10-06-2011, 08:32 PM
  2. RR 08-01-2011 Release
    Last Post: 08-28-2011, 03:41 PM
  3. RR 04-01-2011 Release
    Last Post: 05-18-2011, 11:19 PM
  4. Replies: 21
    Last Post: 04-01-2011, 09:59 AM
  5. RR 02-01-2011 Release
    Last Post: 02-22-2011, 05:46 PM
