-Open RR.INI in notepad
-Find "titlesafter=-" and set it to "titlesafter=" (remove the "-")
-Save, test
If you have don't format text, and ID3 tags disabled, that should be the only thing that can still modify the filenames.
Note that this "titles after" is also in RRConfig right below the option to "Don't format text", if you remove it there and save it, it should also work.
LinkBack URL
About LinkBacks
