Results 1 to 8 of 8
Thread: Winamp Line In Plugin no option to configure
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I've used Winamps Line In for years in conjunction with HD Radio. After a new install and latest winamp on W-7 X86 the line in plugin has no option to configure it. Any idea what happened to this feature?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Windows 7 has different architecture for audio input/recording/mixing - RR supports both new and old for controlling the volumes but some winamp plugins may not. Having said that, there's a good chance you can make it work by messing with the audio settings. Also windows 7 has a "listen" function that does exactly the same as the line in plugin (except built in) you'd only have to set it up in control panel and anytime the radio turned on it would already sound thru the speakers.
    Ride Runner RR's Myspace
    Nov 2007
    PA
    The reason I liked the line in plugin was it "shut off" the audio to the line when switched. I have an Asus Xonar D1 audio card and in the Xonar software has a toggle for "listen" on the line in. The issue is the toggle for listen has to be manually toggled and when I switch from HD radio back to music I still get slight hiss from the line in. If I pause an MP3 I really hear the hiss/noise from the monitored line in. Ill have to dig deeper into windows 7 audio settings I suppose. Thanks.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    My experience is that some win7 drivers don't offer the same features as the drivers for XP - it's reallly a manufacturer thing, but sometimes you just have to mess with it till you find how to enable things.
    MySQL Error
    Oct 2004
    make sure you have manufactures drivers installed
    the winamp line in plugin works fine with win7
    do NOT use the listen function in the control panel, its not ment for use outside the control panel
    as per microsoft lead audio developement guru...
    and winamp line in plugin, i assue you mean jaspers...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Nov 2007
    PA
    Sorry I didn't get a notification there was another response. I was referring to the built in one I see with the default install of the latest build of winamp.
    Jul 2010
    Did you install the winamp line in plugin?
    you need to install it to 'use' it..
    MySQL Error
    Oct 2004
    use jaspers
    http://home.hccnet.nl/th.v.d.gronde/...WA2/index.html
    shame he isnt developing it anymore, but it still works...
    the built in one, i havent tried in years, prob even less developed!
    for sure not as flexible as jaspers's, id consider using this
    advanced, one must understand it before using it
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Winamp Line In Plugin Help...
    By LinuxRacr in forum Car Audio
    Last Post: 12-22-2011, 05:20 PM
  2. Replies: 5
    Last Post: 01-06-2011, 01:28 PM
  3. help with line in plugin please...
    By tja in forum Road Runner
    Last Post: 10-22-2006, 07:33 PM
  4. Xm Line Ine Plugin Bug
    By I302K in forum RR Bug Tracker
    Last Post: 05-17-2006, 12:17 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
